Hi, I am new to arduino and not very advanced in electronics. I have an 18V DC motor from a battery driven power drill which still is connected to all the electronics such as IRFZ44N (Transistor N Channel MOSFET) and a 14069U (Inverter 6-Element CMOS 14-Pin). The 14069U has a sliding potentiometer which ranges from ~1.7Kohm to 480Kohm. I would like to use the arduino to physically emulate that potentiometer in same range of ~1.7Kohm to 480Kohm. Preferably slowing the motor even more down by going higher than 480Kohm. The fast RPM by means of the 1.7Kohm is not of interest to me.
Could I please be pointed in the right direction how to connect and program the Arduino?
Thank you Andreas
You need what is known as a digital pot, google
Arduino digital pot
For examples. I am not too sure they do a 500K one though and most pots can't Handel 18V.
But you might find some that will.
Microchip makes digipots that handle up to 36 volts. I used one to hack a dcdc converter so it was digitally controlled, for the hell of it.
Check how much voltage it actually puts through the pot - maybe you'll be lucky and they pull only put 5 on it
Thanks for your help. I ordered a MCP41100 100k Digi Pot and am going to use it with a 400K resistor sequential as I am only interested in the 400 to 500 k range. And yes there are only going 5V DC through and about 1.5 amps. The whole thing is to be for an extruder to make plastic filament for a 3d Printer. I wanted to save money on a strong stepper motor which drives the auger to push the plastic into the hotend.
Ah!
Check the data sheet but 1.5A sounds way over what a digital pot can take.
That pot has only 1mA wiper current.
That sort of thing is normally controlled with a PWM signal and a big FET.
Hustermouse:
Where is the 1.5 amps? You are not going to get 1.5 amps through 400 to 500 kΩ.
Archibald:
Not without applying 600 to 750 V!
Russell.
I think that takes us back to :
Clearly he's not actually expecting 1.5 amps to go through the pot, since he seems to know he needs 400k-500k ohm resistance.... I have to assume that the pot is used to control something else that in turn controls the 1.5A load....
It might be nice if he'd tell us a bit more about what he's controlling.
russellz:
Not without applying 600 to 750 V!Russell.
No, those are k ohms, not ohms. , you'd need to apply over half a million volts to make 1.5A go through a 400k ohm resistor, and it would pull close to a megawatt.
That would be a nice Arduino project.
Looking forward to seeing the finished project in the gallery.
Make sure there are some nice pictures.
Thanks for all your input! I mentioned i am not a pro in electronics and/or Arduino.
Before I was able to advance it happened that the flimsy sliding potentiometer fell apart. To continue I have two options:
Somebody of you might help me on the way to use the 18V power drill motor to be regulated via voltage change, controlled by the arduino.
I just get a strong stepper motor and do it with the Arduino mega + marlin board + stepper driver as I have on my 3d Prusa i3. Just would need a Arduino program for it.
I just thought I save some money with using what I have.
Back to the amps:
- I adjusted my power supply to 18V and turned the amp button a bit up (didn't display how much)
- disconnected everything from the power drill motor
- connected minus from power supply to black cable on motor.
- connected Fluke 17B's black line to the power supply plus connection
- connected Fluke 17B's other end of black line to black GND on power supply
- connected Fluke 17B's red line to white cable on motor
- connected Fluke 17B's other end of red line to red "amp" (not "mA/uA") connection in the Fluke 17B
- Adjusted Fluke 17B to "Auto Range" setting
Result: at start of motor or trying to stall it by hand it shows 3.6A (not mA) in "Auto Range" setting
the amps then go down to a regular 1.6A (not mA)
Thanks
Andreas
He simples way to control the motor is to have a power FET in seriese with the motor and feed the gate with a PWM signal from the Arduino. There are plenty of tutorials about to do that.
