There seems to be an error with my sketch when I add the potentiometer reading, because the limit switches do not respond. If I were to add a constant speed, the limit switches would work, meaning that the issue is with the part I added for the potentiometer.
#include <ezButton.h>
#include <AccelStepper.h>
#define DIRECTION_CCW -1
#define DIRECTION_CW 1
#define STATE_CHANGE_DIR 1
#define STATE_MOVE 2
#define STATE_MOVING 3
#define MAX_POSITION 0x7FFFFFFF // maximum of position we can set (long type)
ezButton limitSwitch_1(A0); // create ezButton object that attach to pin A0;
ezButton limitSwitch_2(A1); // create ezButton object that attach to pin A1;
AccelStepper stepper(AccelStepper::FULL4WIRE, 3, 4, 7, 8);
int stepperState = STATE_MOVE;
int direction = DIRECTION_CW;
long targetPos = 0;
limitSwitch_1.setDebounceTime(50); // set debounce time to 50 milliseconds
limitSwitch_2.setDebounceTime(50); // set debounce time to 50 milliseconds
stepper.setMaxSpeed(200.0); // set the maximum speed
stepper.setCurrentPosition(0); // set position
limitSwitch_1.loop(); // MUST call the loop() function first
limitSwitch_2.loop(); // MUST call the loop() function first
int sensorReading = analogRead(A2);
// map it to a range from 0 to 100:
int motorSpeed = map(sensorReading, 0, 1023, 0, 100);
// set the motor speed:
if (motorSpeed > 0) {
stepper.setSpeed(motorSpeed);
// step 1/100 of a revolution:
stepper.runSpeed();
if (limitSwitch_1.isPressed()) {
stepperState = STATE_CHANGE_DIR;
Serial.println(F("The limit switch 1: TOUCHED"));
if (limitSwitch_2.isPressed()) {
Serial.println(F("The limit switch 2: TOUCHED"));
switch (stepperState) {
case STATE_CHANGE_DIR:
direction *= -1; // change direction
Serial.print(F("The direction -> "));
if (direction == DIRECTION_CW)
Serial.println(F("CLOCKWISE"));
Serial.println(F("ANTI-CLOCKWISE"));
stepperState = STATE_MOVE; // after changing direction, go to the next state to move the motor
case STATE_MOVE:
targetPos = direction * MAX_POSITION;
stepper.moveTo(targetPos);
stepperState = STATE_MOVING; // after moving, go to the next state to keep the motor moving infinity
case STATE_MOVING: // without this state, the move will stop after reaching maximum position
if (stepper.distanceToGo() == 0) { // if motor moved to the maximum position
stepper.setCurrentPosition(0); // reset position to 0
stepper.moveTo(targetPos); // move the motor to maximum position again
stepper.run(); // MUST be called in loop() function
long targetPos = 0;
stepper.setAcceleration(50.0); // set acceleration
stepper.setSpeed(200); // set initial speed
case STATE_MOVE:
Do the motors move at all when add the potentiometer? Have you added a Serial.println to print the speed? If I auto-format your code the state machine does not execute unless motorSpeed is greater than 0. See below:
stepper.runSpeed();
case STATE_MOVE:
The motor runs and the potentiometer works perfectly with the use of the map command. On the other hand, there doesn't seem to be a response from the limit switches. This is with the aid of the accelstepper library to enable me to change the direction of the motor upon hitting the limit switch, hence the code you observe.
