Arduino to de-energize relay coil
I have a normally open micro switch that is connected to a SPST relay and then to a DC motor reversing circuit that is controlled by an arduino.
The micro switch will only be pressed for a small amount of time, but I need that to start the motor cycle. I achieved this through the use of the relay, but I now need the relay coil to be de-energized after a certain amount of time to stop the motor.
Can this be achieved through the arduino programming?
Thanks!
Don't show the code as a jpeg image. Post it according to the accepted forum methods mentioned in the sticky posts at the top of the forum.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks... Tom.. :slight_smile:
