Arduino to earbuds
Hey everyone! I need to hook up earbuds to my Arduino board and I have no idea how to go about doing that. Do I need resistors? Where do I hook it up? etc. I have the Arduino 101. Thanks!
I have the Arduino Galileo/101
What does that mean? As I understand it there is the Arduino Galileo and there is the Arduino 101, they are two different boards.
Yes. Although it is best to use an amplifier as this puts a lot less load on the pins.
To the pin producing the audio output.
It's the Arduino 101, what amplifiers and resistors do I need?
The minimum resistance on an Arduino I/O pin is 125 Ohms.* If you want to be safe,** put a 125 ohm or greater resistor in series with the output pin. If you are connecting left & right channels to different Arduino pins, use a resistor on each output pin.
If it's too loud, use a higher value resistor. If it's not loud enough you need a headphone amplifier (which you can buy or build). A headphone amp will usually have a volume control so you can make it louder or quieter.
  • The Arduino pins are rated at 40mA absolute maximum. From [u]Ohm's Law[/u], 5V across 125 ohms is 40mA.
** The resistance/impedance of the headphones is added to the resistor value. So for example, if your headphones are 32 Ohms you could use a 100 Ohm resistor and the load would be 132 Ohms, which would be OK. But, a 125 Ohm series will protect the Arduino from any load, including a short (as long as the short is after the resistor).
But I don't think this applies to the 101, that is a totally different processor. It uses a 'Intel Curie', I would be surprised if it is as robust as the Atmel chip.
Edit :- None of the data sheets I have managed to find says what the output source or sink current is.
