hello, i am amila udayanga..
I need to send data from two arduino boards to one esp8266 board.Data comes when an arduino board is used as a receiver. But when esp8266 is used as receiver, no data can be seen in the serial monitor. When I use one transceiver and send "hello world", the data comes into the esp 8266. please help me ..
arduino tranceiver code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <DHT.h>
const uint64_t pipes[2] = {0xE8E8F0F0E1LL,0xE8E8F0F0E2LL};
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
RF24 radio(7, 8); // CN and CSN pins of nrf
int sensorPin = A0; //soil moister pin
struct sensor {
int hum;// humidity
byte tem;// tempereture
byte soil;// soil moisture
byte sensorNum;
//byte y; //soil moisture
sensor amila;
dht.begin();
radio.begin();
radio.setAutoAck(false);
radio.setDataRate(RF24_250KBPS);
radio.openWritingPipe(pipes[1]);
amila.sensorNum=1;
amila.hum = dht.readHumidity();
amila.tem = dht.readTemperature();
amila.soil = analogRead(sensorPin);
// data1.h1 = 90;
// data1.t1 = 30;
if (isnan(amila.hum) || isnan(amila.tem)){
Serial.println(F("Failed to read from DHT sensor!"));
return;
Serial.print("Humidity: ");
Serial.print(amila.hum);
Serial.println("Temperature: ");
Serial.print(amila.tem);
Serial.println("moisture");
Serial.print(amila.soil);
radio.write(&amila, sizeof(amila));
tranceiver 2 arduino uno
#include <SPI.h>
#include <RF24.h>
#include <DHT.h>
#define DHTPIN 4
struct sensor {
byte hum;// humidity
byte soil;//soil moisture
byte sensorNum;
sensor hirusha;
dht.begin();
radio.begin();
hirusha.sensorNum=2;
hirusha.hum = dht.readHumidity();
hirusha.tem = dht.readTemperature();
hirusha.soil = analogRead(sensorPin);
// data1.h1 = 90;
// data1.t1 = 30;
if (isnan(hirusha.hum) || isnan(hirusha.tem)){
return;
Serial.print(hirusha.hum);
Serial.print(hirusha.tem);
Serial.print(hirusha.soil);
radio.write(&hirusha, sizeof(hirusha));
receiver arduino uno/esp8266 (esp8266 not working)
#include <SPI.h>
#include <RF24.h>
//#include <SoftwareSerial.h>// for serial communication
//SoftwareSerial espSerial(18, 19);//for serial..
String str1; //for serial ..
String str2; //for serial ..
const uint64_t pipes[2] ={0xE8E8F0F0E1LL,0xE8E8F0F0E2LL};
RF24 radio(7, 8);
struct sensor {
int hum;
int tem;
int soil;
int sensorNum;
//byte y;
sensor sensorData;
espSerial.begin(115200); //for serial..
radio.begin();
radio.openReadingPipe(1, pipes[1]);
radio.openReadingPipe(2, pipes[2]);
radio.startListening();
// Serial.print(".......Amila udayanga .....\n");
// Serial.println(".....smart irrigation system.....\n\n\n");
//void recvData()
// if ( radio.available() ){
// radio.read(&data1, sizeof(MyData1));
// delay(500);
// radio.read(&data2, sizeof(MyData2));
radio.read(&sensorData, sizeof(sensorData));
disp_sensor_data();
disp_sensor_data();
disp_sensor_data();
disp_sensor_data();
void disp_sensor_data()
if(sensorData.sensorNum == 1)
Serial.print("NODE 1 \n");
Serial.print("HUMIDITY SENSOR 1:");
Serial.println(sensorData.hum);
Serial.print("TEMPERATURE 1:");
Serial.println(sensorData.tem);
Serial.print("soil moisture 1:");
Serial.println(sensorData.soil);
if(sensorData.sensorNum == 2)
Serial.print("NODE 2 !!!!!\n");
Serial.print("HUMIDITY SENSOR 2: ");
Serial.print("TEMPERATURE SENSOR 2: ");
Serial.print("soil moisture 2:");
Serial.print("\n\n");
