Arduino to Excel
So I am trying to take data from the arduino and graph it using excel. Any ideas on how to convert serial data into a .csv file?
Thanks!
There's a PDF explaining how to use the program, a bit of a pain to get used to.. but it works.
Or you can use a VDIP module:
http://www.vinculum.com/prd_vdip1.html
And when creating the file for write, just name it "whatever.CSV"
I've tried both of these and have had success, all though those were some time ago :stuck_out_tongue:
Easiest is to just have your Arduino program write data as numbers separated by commas. For example:
12,34,56,7
9,-3,5,23
etc.
Then, use a terminal program like TeraTerm, Hyperterminal, BrayTerm, etc. etc. (instead of the built-in Serial Monitor) and use the "log to file" feature which saves a copy of everything you see in the terminal to file. Call this file "something.csv" and open it up in Excel/OpenOffice.
Check out our new shield: http://www.ruggedcircuits.com/html/gadget_shield.html
I have heard a lot about the gobetwino, but I have a mac, so I cant use it.
What is the best terminal program to use on a mac?
Dunno about the best, but I'm a fan of minicom. It runs in a Terminal window (it's not a GUI program) but it has lots of features and is small and clean.
is it possible to use the terminal utility that comes on the mac?
Not that I know of. I think it can create SSH/Telnet connections and such but I've not been able to get it to connect to serial ports.
I loaded the ASCII table serial example on my Arduino (removing the while(true) loop so that the sketch would keep running). Then I dropped to a shell and ran this command:
James-MBP:~ james$ cat /dev/cu.usbserial-A4001mCX > test.txt
After a while I hit "ctrl-c" to kill the cat process, and then looked at the what was in "test.txt". The ASCII table was transmitted and stored in a file.
Quick and simple.
Obviously the /dev/cu.usbserial-AXXXXXX will vary on your machine.
we can use PLX-DAQ, a free data acquisition excell add-in from Parallax.
originally it was design to Parallax microcontroller, eg. BS2 & Propeller, but since it use standard serial interface then we can use any microcontroller that have serial port to connect with it.
just google it with keyword "PLX-DAQ Data Acquisition Tool", sorry this is my first post so I can't insert link yet :slight_smile:
Microsoft Windows 98 or higher
Microsoft Office/Excel 2000 or higher
Good suggestion for some users, but the original poster was asking about solutions on OSX.
