i wanted to try something new. I want to create a system where the arduino could send a signal to my lcd if it receives a reply from my hdd connected.
if anyone could assist me with this would be great.
i am novice
thank you
i am novice
thank you
Too hard unless you just want to hear it spinning or measure the current it takes .
How much have You managed to achieve in making the Arduino communicate with the hdd?
i wanted to reformat the hdd using arduino and an lcd touch screen i had through commands like /N1 and others so just wanted to know how to acces these commands through arduion
freaky_creep:
That sounds completely impractical to me. What's wrong with using your PC which already has the software to do it and has the speed.
Or maybe use a RaspberryPi - for the same reasons.
I presume "hdd" means hard disk drive?
...R
freaky_creep:
That makes exactly no sense. ![]()
Maybe attempt to explain it properly?
What is an "arduion"? ![]()
