Arduino to iPod
Hello. I am trying to extract the metadata aka the song title/artist/genre from the ipod on to the arduino and to the lcd. I have ordered and constructed pod breakout mini and contructed a cable, but am unsure of how to proceed from here. Help!
Which one?
First thing you need is an application on the iPod to push the data. Do you have that? What data does it push? To where?
Not sure why this is posted in this forum, but you might find this useful - https://courses.cit.cornell.edu/ee476/FinalProjects/s2007/awr8_asl45/awr8_asl45/index.html
Not sure why this is posted in the forum, but you might find this useful - ECE 4760
Bookmarked! Thanks.
I do have the Cornell Website, but from what I understand, they heavily use the ATMEGA32-16 based on the code library they upload, before the standard. I would need the code to be for the Arduino. And how can I get a software to push the metadata out? I have a iPod nano 4th generation, and am unsure how to load a software on there. It seem sthat I cannot just connect the tx/rx of the ipod to the tx/rx of the Arduino. Suggestions?
You shouldn't need to load additional software on the iPod. If there is a song playing, and you send the correct query in, it should return the track data. That's how docks get the data.
How can i send this query? Also does this involve the serial? ONe more thing. I know the iPod is 3.3v difference and the arduino is 5v. solutions?
Yes, it involves 'the serial'.
https://www.google.co.uk/search?q=arduino+ipod+breakout
First two links:
http://scuola.arduino.cc/en/content/arduino-comunication-iphone-using-podbreakout-v15
so im slightly confused. This is the code ive written just basically to test:
int incomingByte;
void loop(){
if (Serial.available() > 0){
incomingByte = Serial.read();
Serial.print(incomingByte);
else{
Serial.print(1);
And the serial monitor is just giving me 1s... whats going on?
You appear not to have told the iPod to send you anything.
well this is the new code:
Serial.begin(19200);//sets serial com
int dock = digitalRead(0);
Serial.println(dock);
Same problem. Im getting ones. How do I ask the iPod for data?
Does your breakout have the correct resistance on pin 21 to tell the iPod to use Serial Port mode?
Have you looked at the Cornell code? It can't be used as-is, but you should be able to work from it.
How can i connect a resistor to pin 21? and is it 6.8 k? - Serial port mode?
Also, how can i use the cornell code?
would you be able to post your phone number or skype address? im getting a bit desperate
Sorry, no.
All I'm doing is reading the same documentation that I have provided links to.
so could you summarize how to extract the metadata?
what pins do I need. NOT TO CONTROL the iPod but to just receive the metadata?
then how do i send commands to iPod?
