Arduino to matlab
Hi all,
I’m new arduino user, and I don’t know if this section is correct.
I would ask you the following:
is it possible to connect Arduino by matlab?
If yes, how is it possible?
where I can find some material abuot this issue?
thank you a lot for support
If you just mean move data back and forth from matlab and the arduino Yes it should be. Since the arduino can simply be read as a serial data stream you should be able to open a serial object in matlab and read from it.
If you google matlab serial communication many links will come up.
I have not done this explicitly with an arduino but have used serial comm to communicate between matlab and a GPS unit which broadcast via serial as well as an 18f4520 pic.
B
