Arduino to Mysql via USB
Hi guys,
I found the way to keep data from the sensors of Arduino UNO via the ethernet and wifi. Could someone explain me how can I keep data from the sensors not with using wireless and ethernet, just only serial (USB) connection. I mean I want to write value of sensors to mysql database from the serial port. Thanks a lot.
You need to write an application on the PC that listens to the serial port, and talks to the MySQL database. Doing so ranges from trivial to nearly impossible, depending on YOUR skill set.
ok thanks.
