Hey guys, I’m interested in starting my first Arduino project.
I want to be able to read Throttle Body Position or RPM (either way, though preferably the former) on my R1.
I have a Power Commander 5 and software that displays RPM/Gear Position and all sorts of other stats via the software they provide.
I was able to find some documentation on the various inputs, but I’m not sure how to go about hooking it up to the Arduino.
Here’s what I’ve found so far that may be useful.
Power Commander 5 documentation: (some of it)
A program someone wrote to automatically switch fuel maps by reading TPS values (Attached).
What’s not clear to me is how to connect the physical hardware.
Should I use the Analog socket (from documentation?)
Any help would be greatly appreciated
/*---( NOTES )---*/
- PCV AUTO MAP SWITCH
- Rev1.1
- Date 12.06.16
- By L.K.
- Automated fuel map switch for cruising
- Reads throttle position sensor (TPS) voltage on Analog Pin A0
- When cruise conditions are detected, sends 5 volt signal on Pin 13 to switch fuel maps on PCV
- CRUISE CONDITIONS FOR FUEL MAP SWITCH
- MRTI - Minimum run time inhibit
- TPSR - TPS rate of change
- TPSS - TPS smoothness factor
- CONNECTIONS:
- Pin A0 Input voltage from TPS
- Pin 13 Output voltage to PCV / Relay
- REFERENCES:
- http://arduino-info.wikispaces.com/YourDuinoStarter_AnalogValue
- https://www.arduino.cc/en/Tutorial/Smoothing
/*---( Import needed libraries )---*/
//none
/*---( Declare Constants )---*/
#define TPSin A0 // Pin for TPS input voltage
#define PCVout = 13; // Pin for map switch output voltage
#define displayInterval = 500 // Value for time between displaying values on screen (m/s)
const int MRTI = 120000; // Value for minimum run time inhibit (sec)
const int TPSR = 2.5; // Value for TPS rate of change (V/s) - THIS VALUE IS A GUESS
const int TPSS = 5; // Value for TPS smoothness (V^2/s) - THIS VALUE IS A GUESS
const int sampleDuration = 30000; // TPS sampling duration for smoothness averaging (ms)
unsigned long dt = 100; // TPS sampling rate (ms)
/*---( Declare objects )---*/
//none
/*---( Declare Variables )---*/
int numReadings; // Number of samples for averaging
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int TPSaverage = 0; // the average
int TPSinteger; // Reading from the TPS signal as 10 bit value
float TPSvoltage; // TPS value converted to 0-5 volts
float LastVoltage = 0; // TPS starting voltage
elapsedMillis timer; // timer for counting between screen prints
/*---( Setup runs once )---*/
Serial.begin(9600); //Start sending to "Serial Monitor"
Serial.println("PCV AUTO MAP SWITCH"); //Display message on screen
/*-( Initialize all the readings to 0 )-*/
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0; // initialize all the readings to 0
/*---( Loop runs continuously )---*/
/*---( Minimum Run Time Inhibit )---*/
if (millis() < MRTI)
digitalWrite(PCVout, LOW); // no voltage to PCV map switch
Serial.println("Minimum run time inhibit. Please wait."); // Display message on screen
/*---( TPS rate of change )---*/
TPSinteger = analogRead(TPSin); // Read TPS value
TPSvoltage = TPSinteger * (5.0 / 1024.0); // Convert TPS value to Volts
TPSchange = (TPSvoltage-LastVoltage); // Find the change of TPS compared to last reading
LastVoltage = TPSvoltage // Store TPS value for comparison with next reading
TPSrate = (TPSchange/dt); // Find the rate of change of TPS
/*---( TPS smoothness )---*/
numReadings = (sampleDuration/dt); // Number of samples for smoothing TPS
total = total - readings[readIndex]; // Subtract the last reading
readings[readIndex] = TPSchange^2 // Square the TPS rate of change and store in an array
total = total + readings[readIndex]; // add the reading to the total:
readIndex = readIndex + 1; // advance to the next position in the array
if (readIndex >= numReadings) // if we're at the end of the array
readIndex = 0; // wrap around to the beginning:
TPSsmoothness = total / numReadings; // Smoothness of TPS - SEE COMMENT BELOW
timeArray = MRTI + sampleDuration; // Time duration to allow the array to fill up with data
/*---( Check if TPSR and TPSS are ok to switch fuel maps )---*/
if (millis() > timeArray && TPSrate < TPSR && TPSsmoothness < TPSS )
digitalWrite(PCVout, HIGH); // Switch on voltage to PCV map switch
/*---( Print values on screen )---*/
if (timer > interval)
timer -= interval; //reset the timer // Setup timer to print on screen at set intervals
Serial.println("TPS voltage = "); // Display message on screen
Serial.print(TPSvoltage, 3); // Print value
Serial.print(" V"); // Print value
Serial.println("TPS rate of change = "); // Display message on screen
Serial.print(TPSrate, 3); // Print value
Serial.print(" V/s"); // Print value
Serial.println("TPS smoothness = "); // Display message on screen
Serial.print(TPSsmoothness, 3); // Print value
Serial.print(" V^2/s"); // Print value
delay(dt); // Wait until next sample
/*---( End loop )---*/
PCV Auto Map Switch Rev1.1.txt (5.27 KB)
