Hi all,
I’m busy with a project in processing where I made a rogram which I can control with the arrow keys.
int maxImages = 5; // Total number of images
int i = 0;
int firstImage = i; // First image defined
int p = 1;
int pixelImage = p;
int pixelSize;
PImage[] img = new PImage[maxImages]; // Array of images
size(500, 500);
void draw() {
for (int firstImage = i; firstImage < img.length; firstImage++) {
img[firstImage] = loadImage(firstImage + ".jpg");
pixelateImage(p); // Change pixel size
void pixelateImage(int pixelSize) {
// use ratio of height/width...
float ratio;
if (width < height) {
ratio = height/width;
ratio = width/height;
// ... to set pixel height
int pixelHeight = int(pixelSize * ratio);
noStroke();
for (int x=0; x<width; x+=pixelSize) {
for (int y=0; y<height; y+=pixelHeight) {
fill(img[firstImage].get(x, y));
//rectMode(CENTER);
rect(x, y, pixelSize, pixelHeight);
void keyPressed() {
if (key == CODED) {
if (keyCode == LEFT) {
// Next image when mouse is clicked
// Note the index to the array must be an integer!
firstImage ++;
if (firstImage > 4) {
firstImage = 0;
if (keyCode == RIGHT) {
firstImage --;
if (firstImage < 0) {
firstImage = 4;
if (keyCode == UP) {
p = (p+10);
if (p > 250) {
p = 250;
if (keyCode == DOWN) {
p = (p-10);
if (p < 1) {
p = 1;
As you can see with the right and left arrow you can scroll through the different images and with the up and down arrow you can change the pixel size.
Now I want to connect the program with Arduino and use one pushbutton to scroll through the images so when you push the button you go to the next image and when you’re at the last image you go back to the first image and start over again. Further I want to connect the pixel size to a ultrasonic sensor. So when you hand is close to the sensor the image should be scharp (1 px x 1 px) and when you are further away like 50 cm the image schould be pixelated (250 px x 250 px). I think the values should be like:
… - 10 cm → 1px x 1px
10 - 20 cm → 50 px x 50 px
20 - 30 cm → 100 px x 100 px
30 - 40 cm → 150 px x 150 px
40 - 50 cm → 200 px x 200 px
50 - … cm → 250 px x 250 px
Can anybody help me with connecting arduino and processing and get the right data input.
Thanks MB
