Below is the code I created in an attempt to transmit data from Arduino to Visual Basic 6:
VB Code:
Dim temp(2) As String
Dim Buffer As String
Private Sub Form_Load()
Arduino.CommPort = 4
Arduino.Settings = "9600,N,8,1"
Text1.MultiLine = True
End Sub
Private Sub Command1_Click()
Arduino.PortOpen = True
End Sub
Private Sub Arduino_OnComm()
If (Arduino.CommEvent = comEvReceive) Then
Buffer = Arduino.Input
temp = Split(Buffer, " ")
Text1.Text = temp(0) + vbCrLf + temp(1)
Arduino.InBufferCount = 0
Arduino.Output = (" ")
End If
End Sub
Private Sub Form_Unload(Cancel As Integer)
Arduino.PortOpen = False
End Sub
Arduino Code:
[color=#CC6600]long[/color] randNum;
char chInput; byte ctr;
void [color=#CC6600]setup/color{ Serial.[color=#CC6600]begin/color;
[color=#CC6600]randomSeed/color;
} void [color=#CC6600]loop/color{ for (ctr=1; ctr <= 2; ctr++){ //transmit two random integers from 0 - 99 as a test
randNum = [color=#CC6600]random/color; if (randNum < 10){ Serial.[color=#CC6600]print/color;
} Serial.[color=#CC6600]print/color; Serial.print(" ");
} Serial.println(" "); do {
chInput = Serial.[color=#CC6600]read/color;
[color=#CC6600]delay/color;
} while (chInput != 32); //wait for spacebar
Although the Arduino sketch is running fine, I can't run the VB6 form properly because it always crashes as soon as I click the command button.
So far, I'm certain that I'm using COM4 for my VB code, where I connected the Arduino. Also, nothing else is using it.
I'm trying to execute the VB code with the Arduino IDE closed, because I assume that the sketch is already stored in the MCU. I think something wrong is going on when VB is trying to open the com port, leading to a freeze.
You think that maybe if you do something wrong in a different place, that might work better? I guess you could try that, but I'm not counting on it working. A read-only property is read-only, no matter where you try to write to it.
There is an Open method that you should be using, instead. When Open() successfully opens the serial port specified, it sets the variable that the PortOpen property exposes to true.
I'm afraid I have to disagree with PaulS . 'com_object.PortOpen = True' is how you open a comm port with VB6 Comm control. I'm no expert, but its worked for me in the past.
I have a peice of code that may come in handy for you. It checks the comm ports avaiable on the machine from 1 to 20 and puts a list of available com ports in a Listbox. You could then choose a port from this list, set the com_object.CommPort from this. Then set the com_object.Settings
' ### You will need a listbox on your form called list1 to use this code.
' ### list com ports on machine
For I = 1 To 20 ' ### Change this for different ports. Starts at com1 and goes to com20
On Error Resume Next
com.CommPort = I
com.PortOpen = True
com.PortOpen = False
' # if port exists add to list
If (Str(Err.Number) = 0) Then
List1.AddItem (Str(I)) ' ### Adds port number to list1 as a string
End If
Next I
End Sub
' ### the command below will assign the comport from the selected port in the list box
' ### com.CommPort = Val(List1.text)
I currently don't have access to a PC with VB6 on it but this is code I have used in the past. I've just chopped out a couple of bits and pasted them together.
Hope this helps
btw The port list routine isn't my work, its from zeb here
I decided to test the code again: once without the Arduino plugged in, and once with it plugged in. This time, I replaced the Arduino code with "Hello World" and I rewrote the VB6 code to read "Hello World" from Arduino's serial output.
Clicking the command button with Arduino.PortOpen = True never triggered a freeze until I plugged the Arduino in.
Testing it once more, I decided to use Arduino to send a single character through the serial port, which flawlessly worked. Then I used it to send a string, which VB6 failed to handle no matter the value of Arduino.RThreshold.
Should I bypass this through sending each character of the string one-by-one? Also, since this page suggests that an extra character would be needed in a character array to accommodate a null character, where does the null character go? The only solution seems to be converting the output numbers into strings.
Atleast set these parameter in your comm object, most parameter can set in design time:
inputMode=1 'comInputModeBinary ; why you can set text aswell as special character.
NullDiscard=true
RThreshold=1
RTSEnable=true
settings=9600,n,8,1 ' baud as your choice
commport=x 'x= your port ID
SThreshold=1
