Arduino to Web via enc28j60 shield problem.
Good Day. Please take a look with my problem.
My Code:
ether.packetLoop(ether.packetReceive());
if (millis() > timer) {
timer = millis() + 1000;
Serial.print("<<< REQ “);
ether.hisport = 80;//to access local host
itoa(myInt, myIntAsString, 10); //integer 10 to converted as a character
char finalString = {‘v’,‘a’,‘l’,‘u’,‘e’,’=’,myIntAsString[1],myIntAsString[2],myIntAsString[3],};
ether.browseUrl(PSTR(”/atmos.php?"), finalString , website, my_callback);
The Serial Monitor:
[webClient]
IP: 192.168.0.100
GW: 192.168.0.1
DNS: 192.168.0.1
SRV: 192.168.0.110
<<< REQ
<<< REQ
<<< REQ
<<< REQ >>>
HTTP/1.1 200 OK
Date: Thu, 25 Feb 2016 08:13:26 GMT
Server: Apache/2.4.17 (Win32) OpenSSL/1.0.2d PHP/5.6.15
X-Powered-By: PHP/5.6.15
Content-Length: 0
Connection: close
Content-Type: text/html; charset=UTF-8
<<< REQ >>>
HTTP/1.1 200 OK
Date: Thu, 25 Feb 2016 08:13:27 GMT
Content-Length: 0
Connection: close
*loops forever with OK Requests
Problem is: Is there a problem with my network, hardware, or arduino codes that makes 1st REQ does not reply OK? Some test cases I got OK in the 1st REQ but most of the time i got it after a number of failed REQ.
Thanks in advance! :slight_smile:
We can't possibly tell from that snippet. Post ALL of your code PROPERLY. Read the stickies at the top of the forum BEFORE you post again. Use Tools + Auto Format to properly indent your code before posting it.
      char finalString[] = {'v','a','l','u','e','=',myIntAsString[1],myIntAsString[2],myIntAsString[3],};
There is no guarantee that the conversion of an int to a string will result in a 4 byte string. Even if it does, why do you want to throw away the first character? (Array indices start at 0, not 1.)
