Hey, i have recently purchased an arduino BT and im having problems uploading any programs to it. I am using Arduino 18 but the tools > serial option to select the com port is greyed out. i am not sure what to do. Thanks in advance. this is my preferences.txt
default size for the main window
default.window.width = 500
default.window.height = 600
font size for editor
editor.font=Monospaced,plain,12
Monaco is nicer on Mac OS X, so use that explicitly
editor.font.macosx = Monaco,plain,10
anti-aliased text, turned off by default
editor.antialias=false
color to be used for background when 'external editor' enabled
editor.external=false
caret blinking
editor.caret.blink=true
area that's not in use by the text (replaced with tildes)
editor.invalid=false
console = true
console.output.file = stdout.txt
console.error.file = stderr.txt
console.lines = 4
set to false to disable automatically clearing the console
each time 'run' is hit
console.auto_clear = true
set the maximum number of lines remembered by the console
the default is 500, lengthen at your own peril
console.length = 500
convert tabs to spaces? how many spaces?
editor.tabs.expand = true
editor.tabs.size = 2
automatically indent each line
editor.indent = true
size of divider between editing area and the console
editor.divider.size = 0
the larger divider on windows is ugly with the little arrows
this makes it large enough to see (mouse changes) and use,
but keeps it from being annoyingly obtrusive
editor.divider.size.windows = 2
any additional java options when running externally
(for applets that are run external to the environment...
those with a code folder, or using any libraries)
if you hose this and can't run things, it's your own durn fault
run.options =
settings for the -XmsNNNm and -XmxNNNm command line option
run.options.memory = false
run.options.memory.initial = 64
run.options.memory.maximum = 256
example of increasing the memory size for applets run externally
#run.options = -Xms128m -Xmx1024m
index of the default display to use for present mode
(this setting not yet completely implemented)
run.display = 1
set internally
#run.window.bgcolor=
set to false to open a new untitled window when closing the last window
(otherwise, the environment will quit)
default to the relative norm for the different platforms,
but the setting can be changed in the prefs dialog anyway
#sketchbook.closing_last_window_quits = true
#sketchbook.closing_last_window_quits.macosx = false
#history.recording = true
for advanced users, enable option to export a library
#export.library = false
which platforms to export by default
export.application.platform.windows = true
export.application.platform.macosx = true
export.application.platform.linux = true
whether or not to export as full screen (present) mode
export.application.fullscreen = false
whether to show the stop button when exporting to application
export.application.stop = true
false will place all exported files into a single .jar
export.applet.separate_jar_files = false
set to false to no longer delete applet or application folders before export
export.delete_target_folder = true
may be useful when attempting to debug the preprocessor
preproc.save_build_files=false
allows various preprocessor features to be toggled
in case they are causing problems
preprocessor: pde.g
preproc.color_datatype = true
preproc.web_colors = true
preproc.enhanced_casting = true
preprocessor: PdeEmitter.java
preproc.substitute_floats = true
#preproc.substitute_image = false
#preproc.substitute_font = false
auto-convert non-ascii chars to unicode escape sequences
preproc.substitute_unicode = true
PdePreproc.java
writes out the parse tree as parseTree.xml, which can be usefully
viewed in (at least) Mozilla or IE. useful when debugging the preprocessor.
preproc.output_parse_tree = false
imports to use by default (changed for 0149, some imports removed)
preproc.imports = java.applet,java.awt,java.awt.image,java.awt.event,java.io,java.net,java.text,java.util,java.util.zip,java.util.regex
set the browser to be used on linux
browser.linux = mozilla
set to the program to be used for launching apps on linux
#launcher.linux = gnome-open
FULL SCREEN (PRESENT MODE)
run.present.bgcolor = #666666
run.present.stop.color = #cccccc
starting in release 0159, don't use full screen exclusive anymore
run.present.exclusive = false
use this by default to hide the menu bar and dock on osx
run.present.exclusive.macosx = true
ARDUINO PREFERENCES
board = atmega328
target = arduino
upload.using = bootloader
serial.port=COM1
serial.databits=8
serial.stopbits=1
serial.parity=N
serial.debug_rate=115200
serial.burn_rate = 115200
