The qprox sensor is dead easy... you dont need the e11x just get the qt113 chip and you'll find plenty of examples on how to build the circuit... you only need 1 cpacitor.... then the output is active low.... this means that when somebody touches the output goes from 5v to 0v and you can detect that using a digital input pin.
the phidget sensor is even simpler one pin goes to 5v the other to ground and the third one to a digital pin... the output is the same as before.
the tekscan is slightly more complex... yout need to build this circuit
i am experimenting both with the phidgets touch sensor i linked to above, and a phidgets force sensing resistor (FSR), outlined here.
my question is re: the FSR. i modified this example code, originally intended for a piezo element to work with my new FSR.
my question is this: as the code stands (pasted below), arduino pings the analog input every 150ms for a value to decide whether to switch the LED. the problem is that if a person holds onto the FSR, the LED blinks on/off as it senses the hold every 150ms.
i envision a parameter where arduino only pings the input if the value is below a certain value - that way, the LED will only turn on or off if you have already let go of the FSR. but i cannot code it! please help? hope this is understandable...
EDIT: also, how do i change the sensitivity of the phidgets touch sensor (#1110)? thanks so much everybody
/* Knock Sensor
Program using a Piezo element as if it was a knock sensor.
We have to basically listen to an analog pin and detect
if the signal goes over a certain threshold. It writes
"knock" to the serial port if the Threshold is crossed,
int ledPin = 13; // led connected to control pin 13
int knockSensor = 0; // the knock sensor will be plugged at analog pin 0
byte val = 0; // variable to store the value read from the sensor pin
int statePin = LOW; // variable used to store the last LED status, to toggle the light
int THRESHOLD = 5; // threshold value to decide when the detected sound is a knock or not
pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
val = analogRead(knockSensor); // read the sensor and store it in the variable "val"
if (val >= THRESHOLD) {
statePin = !statePin; // toggle the status of the ledPin (this trick doesn't use time cycles)
digitalWrite(ledPin, statePin); // turn the led on or off
Serial.println("Knock!"); // send the string "Knock!" back to the computer, followed by newline
delay(150); // we have to make a delay to avoid overloading the serial port
Posted by: christolles Posted on: 20.10.2006 at 00:57:06
anybody have advice on dimming the LEDs on and off?
ok.
I have been working to do some thing similar to you question
I am using a force sensing resitor -fsr- to make my mac talk
so to make the led be on while you press .
add
int ledPin = 13; // LED connected to digital pin 13
on set up add this
on loop find the the code where the piezo sends data
and add
digitalWrite(ledPin, HIGH); // sets the LED on
then place the digitalWrite(ledPin, LOW); // sets the LED off//
