Arduino troubleshot with MySQL library and connection to computer
problem solved
Could you help me to make an INSERT ?
Until you are able to connect, that would be pointless.
Try connecting the Arduino with ethernet shield to your router, NOT your PC.
I don't have any router
My job is to make them connect directly between the computer ( database ) and the arduino , without anything else on the network.
Switch can do things that i would not understand, if you can't answer it's ok but don't tell me to use something that i would not use because i don't have one.
It's ok , i'm trying to use an ethernet shield 1 now to see if something change
How do you get your PC to connect to the internet, so you could post this?
I'm using what's called a Phone , do you know what is it ?
Man , i don't want to use a PHP page or a switch , my job for that project school is to communicate directly with the pc/database on it.
If you still dodge via other answers then don't anwser me , that doesn't help me.
Bye
PaulS raised valid points.
With an attitude like that, I wouldn't expect anyone to help you.
Pieter
