Arduino trubbleshooting
I was trying to upload a Sketch. But it took a very long time. At the end it says that it is unable to upload to
the Board. Help under http://www.arduino.cc/en/Guide/Troubleshooting#upload.
I checked every point on this Webside but it still won´t work. I selected the Arduino Nano and the Port under the Tools Tab. I also reinstalled the drivers for the CH340G.
2 Months before everything worked without a problem. In this time I reinstalled the Arduino Software.
I dont know what I should do.
This is my Sketch:
#include <LiquidCrystal.h>
LiquidCrystal lcd (12, 11, 9, 8, 7, 6);
lcd.begin(16, 2);
lcd.print(“Hello World”);
This is the Failure:
Arduino: 1.8.7 (Windows 8.1), Board: “Arduino Nano, ATmega328P”
Der Sketch verwendet 1688 Bytes (5%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 57 Bytes (2%) des dynamischen Speichers, 1991 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xee
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xee
Dieser Bericht wäre detaillierter, wenn die Option
“Ausführliche Ausgabe während der Kompilierung”
in Datei → Voreinstellungen aktiviert wäre.
"Programmer not responding" means it was unable to communicate with the Nano in any way.
Does your computer make the USB-connect noise when you plug it in? Check your drivers again.
Can you load this program with another computer and then try it again on the problem computer and see if you get the "hello" on the serial port?
If the Arduino Nano you use is older (or a chinese clone) you should use the old Bootloader. Under Tools → Processor select “ATmega328P (old bootloader)” that should probably fix your problem.
Any other computer program that occupies this USB port? Another instance of IDE f ex.
Thx it Worked I changed the ATmega328P to the old bootloader.
