hi, i am on a project that records and play audio.
my speaker is always on and give noise even if nothing playing. is there any way to disable speaker when nothing plays? i tried audio.disable(); function but it didnt help.
edit: i dont use amplifier. it is phone speaker low volume enaugh. and i connected D9 pin to my speaker.
related part
if (!flag && recmode) {
recmode = 0;
digitalWrite(4, LOW);
Serial.print("kayıt durdu");
audio.stopRecording(audioFilename);
audio.play(audioFilename);
previousMillis2=millis();
delay(5000);
audio.disable();//disable speaker
all code
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 10
TMRpcm audio;
//button definition
bool recmode = 0;
int audiofile = 0;
unsigned long i = 0;
//record different files
uint32_t myFileNumber ;
char audioFilename[13];
bool flag=0;
//hcr04 distance sensor
#define trigPin 6
#define echoPin 5
#define hookpin 2 //flag=digitalread(hookpin)
long duration;
int distance;
//define electromagnet
#define magnet1 7
#define magnet2 8
unsigned long currentMillis=0;
unsigned long previousMillis = 0;
unsigned long previousMillis2 = 0;
int ringCounter=0; //to protect selenoid for overwork
unsigned long previousMillis3=0;
//eeprom store to not overwrite
#include <EEPROM.h>
int address = 0;
byte value;
pinMode(A0, INPUT);
pinMode(4, OUTPUT);//record LED
audio.speakerPin = 9;
pinMode(LED_BUILTIN, OUTPUT);//bultinled to check sd
SD.begin(SD_ChipSelectPin);
audio.CSPin = SD_ChipSelectPin;
// myFileNumber=(analogRead(A0)*1000); //give random to file name
pinMode(hookpin,INPUT);
pinMode(trigPin,OUTPUT);
pinMode(echoPin,INPUT);
//define elctromagnet
pinMode(magnet1,OUTPUT);
pinMode(magnet2,OUTPUT);
while (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD okunamadı");
digitalWrite(LED_BUILTIN,HIGH);
Serial.println("SD OK");
digitalWrite(LED_BUILTIN,LOW);
audio.play("sdcard.wav");
delay(3000);
//Test REC
Serial.println("kayıt baslıyor");
Serial.println("2");
Serial.println("1");
Serial.println("kayıt");
audio.startRecording("test1.wav", 16000, A0);
delay(2000);
audio.stopRecording("test1.wav");
Serial.println("kayıt ok");
audio.play("test1.wav");
Serial.println("play");
delay(2000);
//EEPROM FOR not overwrite
value = EEPROM.read(address);
if(value>1) myFileNumber=value;
//audio record and stop
flag=!(digitalRead(hookpin));//hookpin
Serial.print("flag-hookpin: ");Serial.println(flag);
//used 2 parameter one for check hook is pressed the other we re recordin or stopping phase
if (flag && !recmode ) {
audio.play("anons.wav"); //play user note
delay(7500);
digitalWrite(4, HIGH);
recmode = 1;
myFileNumber++;
//EEPROM
if(myFileNumber>30000) myFileNumber=1; //protect to overflow
EEPROM.write(address, myFileNumber);
itoa(myFileNumber,audioFilename,10);//continous file record
strcat(audioFilename, ".wav");
Serial.println("kayıt başladı,dosya ismi:");Serial.println(audioFilename);
audio.startRecording( audioFilename, 16000, A0);
recmode = 0;
delay(5000);
//calculate distance
if(flag==0) {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); //Sets the trigPin HIGH (ACTIVE) for 10 microseconds
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
// Displays the distance on the Serial Monitor
Serial.print("distance: ");Serial.println(distance);
//ring phone
currentMillis=millis();
if (currentMillis-previousMillis3>180000){ //bell can run max 10 times in 3 min
previousMillis3=millis();
ringCounter=0;
if((flag==0) && (distance<200) && (distance>3)&&(currentMillis-previousMillis>5000) &&(currentMillis - previousMillis2 >= 30000) && (ringCounter<10)){
previousMillis=millis();
ringCounter=ringCounter+1;
Serial.println("*****************ring************");
Serial.println(ringCounter);
for (int i=0; i<15;i++){
if (flag) break; //stop if hook rises
digitalWrite(magnet1,HIGH);
digitalWrite(magnet2,LOW);
delay(50);
digitalWrite(magnet1,LOW);
digitalWrite(magnet2,HIGH);
delay(50);
delay(80);
