I'm using an MKR 1010, and receiving an error "A1 was not declared in this scope, did you mean A0"
Also, in the error message window it further states 'In void printWeb.
Another error is listed as "PinStatus does not have a type" "293 | static PinStatus digitalRead(uint8_t Pin .
I am attaching the sketch (from Arduino.cc/tutorials...
#include <WiFiNINA.h>
char ssid[] = "XXXX"; // your network SSID (name) between the " "
char pass[] = "XXXX"; // your network password between the " "
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS; //connection status
WiFiServer server(80); //server socket
WiFiClient client = server.available();
int ledPin = 2;
pinMode(ledPin, OUTPUT);
while (!Serial);
enable_WiFi();
connect_WiFi();
server.begin();
printWifiStatus();
if (client) {
printWEB();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void enable_WiFi() {
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
void connect_WiFi() {
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
void printWEB() {
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
//create the buttons
client.print("Click <a href=\"/H\">here</a> turn the LED on<br>");
client.print("Click <a href=\"/L\">here</a> turn the LED off<br><br>");
int randomReading = analogRead(A1);
client.print("Random reading from analog pin: ");
client.print(randomReading);
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
if (currentLine.endsWith("GET /H")) {
digitalWrite(ledPin, HIGH);
if (currentLine.endsWith("GET /L")) {
digitalWrite(ledPin, LOW);
// close the connection:
client.stop();
Serial.println("client disconnected");
Here is the error message
Arduino: 1.8.19 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\brin8\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\brin8\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Arduino_ProjectS\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M64,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\brin8\AppData\Local\Temp\arduino_build_19185 -warnings=none -build-cache C:\Users\brin8\AppData\Local\Temp\arduino_cache_709789 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.python3.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -verbose C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\brin8\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\brin8\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Arduino_ProjectS\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M64,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\brin8\AppData\Local\Temp\arduino_build_19185 -warnings=none -build-cache C:\Users\brin8\AppData\Local\Temp\arduino_cache_709789 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.python3.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -verbose C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino
Using board 'generic' from platform in folder: C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/mkbuildoptglobals.py" "C:\Program Files (x86)\Arduino" 10819 "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185" "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG/HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.globals.h" "C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266/CommonHFile.h"
default_encoding: cp1252
Assume aggressive 'core.a' caching enabled.
Clean build, created dir C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\core
Note: optional global include file 'C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.globals.h' does not exist.
Read more at How to specify global build defines and options — ESP8266 Arduino Core 3.1.2-6-ga76ef290 documentation
Detecting libraries used...
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\sketch\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.cpp" -o nul
Alternatives for WiFiNINA.h: [WiFiNINA@1.8.13]
ResolveLibrary(WiFiNINA.h)
-> candidates: [WiFiNINA@1.8.13]
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\sketch\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\WiFi.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\WiFiClient.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\WiFiSSLClient.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\WiFiServer.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\WiFiStorage.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\WiFiUdp.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\utility\WiFiSocketBuffer.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\utility\nano_rp2040_support.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\utility\server_drv.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\utility\spi_drv.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\utility\spi_drv.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI" "C:\Arduino_ProjectS\libraries\WiFiNINA\src\utility\wifi_drv.cpp" -o nul
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI" "C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI\SPI.cpp" -o nul
Generating function prototypes...
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI" "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\sketch\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.cpp" -o "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/signing.py" --mode header --publickey "C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG/public.key" --out "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/Updater_Signing.h"
"C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core/build.opt" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\brin8\AppData\Local\Temp\arduino_build_19185/core" -c "@C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_GENERIC"" "-DARDUINO_BOARD_ID="generic"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\generic" "-IC:\Arduino_ProjectS\libraries\WiFiNINA\src" "-IC:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI" "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\sketch\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.cpp" -o "C:\Users\brin8\AppData\Local\Temp\arduino_build_19185\sketch\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino.cpp.o"
In file included from C:\Arduino_ProjectS\libraries\WiFiNINA\src/WiFiStorage.h:23,
from C:\Arduino_ProjectS\libraries\WiFiNINA\src/WiFi.h:38,
from C:\Arduino_ProjectS\libraries\WiFiNINA\src/WiFiNINA.h:23,
from C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino:2:
C:\Arduino_ProjectS\libraries\WiFiNINA\src/utility/wifi_drv.h:293:12: error: 'PinStatus' does not name a type
293 | static PinStatus digitalRead(uint8_t pin);
C:\Arduino_Projects\HOST_A_WEBSER_USING_MKR_1010_ORIG\HOST_A_WEBSER_USING_MKR_1010_ORIG.ino: In function 'void printWEB()':
HOST_A_WEBSER_USING_MKR_1010_ORIG:107:44: error: 'A1' was not declared in this scope; did you mean 'A0'?
107 | int randomReading = analogRead(A1);
| A0
Using library WiFiNINA at version 1.8.13 in folder: C:\Arduino_ProjectS\libraries\WiFiNINA
Using library SPI at version 1.0 in folder: C:\Users\brin8\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI
exit status 1
Did not try to change it to A0, because I could not find a reference to either in the sketch
Suggestions would be appreciated.
Mike
