arduino twitter Help
Hello, im experimenting on using the Serial monitor to upload strings on twitter, i have written a code that fetches user input string but some reason, it doesn’t work, code compiles fine…need some help to debug!
#include <SPI.h>
#include <Ethernet.h>
#include <Twitter.h>
boolean MsgSent = false;
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {192, 168, 2, 50 };
Twitter twitter("XXXXX");
EthernetClient client;
char msg[140];
int delayS = 10;
void softReset() {
  asm volatile ("jmp 0");
  if (Ethernet.begin(mac) == 0)
    Serial.println("Failed to configure Ethernet using DHCP");
    while(true);
 Serial.println("type in what you wanna tweet");
char tweet;
int i =0;
tweet = Serial.read() ;
  if(Serial.available() > 0) {
    snprintf(msg, 140, "%c" , tweet);
    i++;
    Serial.println("Delaying ...");
    for(int i = 0; i < delayS; i++) {
      Serial.print(i);
      Serial.print(" ");
    Serial.println("connecting ...");
    if (twitter.post(msg)) {
      int status = twitter.wait(&Serial);
      if (status == 200) {
        Serial.println("OK.");
      else {
        Serial.print("failed : code ");
        Serial.println(status);
        Serial.print("\n");
      softReset();
Cheers!!
Anyone?
Do you know if the twitter.h library is still valid?
I recall Twitter made a lot of changes to their API recently that may have broken it.
Hi yes I is, I used it recently
