Hi All really stund
I've tested loade tried all the code i can find but not luck
#include <Twitter.h>
#include <SPI.h> // needed in Arduino 0019 or later
#include <Ethernet.h>
// The includion of EthernetDNS is not needed in Arduino IDE 1.0 or later.
// Please uncomment below in Arduino IDE 0022 or earlier.
//#include <EthernetDNS.h>
// Ethernet Shield Settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// If you don't specify the IP address, DHCP is used(only in Arduino 1.0 or later).
byte ip[] = { 192, 168, 2, 250 };
// Your Token to Tweet (get it from http://arduino-tweet.appspot.com/)
Twitter twitter ("mycode");
// Message to post
char msg[] = "Hello, World! I'm Arduino!";
delay(2000);
Ethernet.begin(mac, ip);
// or you can use DHCP for autoomatic IP address configuration.
// Ethernet.begin(mac);
Serial.println("connecting ...");
if (twitter.post(msg)) {
// Specify &Serial to output received response to Serial.
// If no output is required, you can just omit the argument, e.g.
// int status = twitter.wait();
int status = twitter.wait(&Serial);
if (status == 200) {
Serial.println("OK.");
Serial.print("failed : code ");
Serial.println(status);
Serial.println("connection failed.");
but I'm unable to get this working all i get is
connecting ...
connection failed.
any help thanks
