arduino uno +6 servo+12v dc motor 300rpm (6)
how to control 6 servo motor + 12v dc motor 3000rpm using arduino uno
how many motors maximum controlled by arduino uno
using all digital pins
controlling 6 servo using arduino uno
the 5v pin enough to power?
(or) how to power those motors?
12 Servos
https://www.arduino.cc/en/Reference/Servo
You can do 20 of other types (you have 20 digital pins to use), on/off only, with appropriate power supply and drive electronics (a transistor/motor at least).
No. You should plan for at least an amp per servo. 5V pin can’t supply that.
Couple of these for example.
Be sure to connect all power supply -'s together and to the Arduino Gnd.
6 servo+ 6 12v dc motor
You can stack Adafruit motor shields.
without shield passible
deena8:
Define "control". on-off? speed? bidirectional on-off-on, bidirectional speed control?
@Deena8
Please do not start new threads for the same topic. All threads merged.
deena8:
I googled "diy arduino motor control" and I found MANY MANY examples, tutorials, articles and instructibles on the subject.
Give it a try! :slight_smile:
