ARDUINO uno accelerometer
Hi I'm using an Arduino uno to program a LIS2DH St accelerometer via SPI. The values I get don't really make sense..I'm not sure if I'm doing something wrong in the code. Can anyone please check it?
#include <SPI.h>
//Register Addresses
const int OUT_X_L = 0x28; //X-axis acceleration data
const int OUT_X_H = 0x29;
const int OUT_Y_L = 0x2A; //Y-axis acceleration data
const int OUT_Y_H = 0x2B;
const int OUT_Z_L = 0x2C; //Z-axis acceleration data
const int OUT_Z_H = 0x2D;
const byte READ = 0b10000000;
const int CS = 10;
 pinMode(CS,OUTPUT);
 SPI.begin();
 //our device requires data to be sent MSB
 //(most significant byte) first, pg. 23
 SPI.setBitOrder(MSBFIRST);
 //clock is idle high and data is shifted in and out
 //on the rising edge of the data clock signal, pg. 23
 SPI.setDataMode(SPI_MODE3);
 SPI.setClockDivider(SPI_CLOCK_DIV2);
 //Create a serial connection to display the data on the terminal.
 //writeRegister(CTRL_REG1,0x07);
 delay(100);
 Serial.print(" x = ");
 Serial.print(readval(1));
 Serial.print(" y = ");
 Serial.print(readval(2));
 Serial.print(" z = ");
 Serial.println(readval(3));
 delay (500);
unsigned int readRegister(byte x) {
   unsigned int r=0;
   byte b = x | READ;
   digitalWrite (CS, LOW);
   SPI.transfer(b);
   r = SPI.transfer (0x00);
   digitalWrite (CS, HIGH);
   return r;
int readval (int x) {
 int val = 0;
 byte h, l;
   if (x==1) {
      l = readRegister(OUT_X_L);
      h = readRegister(OUT_X_H);
        else if (x == 2) {
        l = readRegister(OUT_Y_L);
        h = readRegister(OUT_Y_H);
           else if (x == 3) {
           l = readRegister(OUT_Z_L);
           h = readRegister(OUT_Z_H);
    val = ( (h<<8 ) | l);
    return val;
What are the values you are getting? What is the test setup? What values did you expect to get with that setup?
Yes, we do know that 8 ) makes the 8) smiley. You can still go back and edit your first post to fix that error.
edocchipi97:
Now does anyone else have any useful suggestions?
Edit your post to add the code tags you forgot.
You're welcome.
We don't need to assume you didn't read the instructions; it's clear you didn't.
