Arduino Uno - Adafruit Fingerprint Sensor
I’m working with the adafruit fingerprint sensor and library. In the examples there is a code for enrolling new users and a code for searching the sensor for existing fingerprints. I was trying to merge both codes with an if-statement, but only one function is being entered (enrolling).
Here’s the whole code, in one function I replaced ‘p’ with ‘n’, the default variable is ‘p’ in both functions.
Any idea how I can let the code enter the searching function?
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
int getFingerprintIDez();
uint8_t getFingerprintEnroll(uint8_t id);
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  //pinMode(button, INPUT);
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
  delay(50);
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
void loop()                     // run over and over again
  Serial.println("For Enrolling Press 1, For Searching Press 2");
  delay(50);
   int key=0;
  while (true) {
    while (! Serial.available());
    char k = Serial.read();
    if (! isdigit(k)) break;
    key = k - '0';
  if(key == 1)
Serial.println("Type in the ID # you want to save this finger as...");
  uint8_t id = 0;
  while (true) {
    char c = Serial.read();
    if (! isdigit(c)) break;
    id *= 10;
    id += c - '0';}
    Serial.println("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll(id) );
  if(key ==2)
  Serial.println("Waiting for valid finger...");
  delay(50);
//don't ned to run this at full speed.
uint8_t getFingerprintID() {
  uint8_t n = finger.getImage();
  switch (n) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return n;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return n;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return n;
    default:
      Serial.println("Unknown error");
      return n;
  // OK success!
  n = finger.image2Tz();
  switch (n) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return n;
      return n;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return n;
    case FINGERPRINT_INVALIDIMAGE:
      return n;
    default:
      return n;
  // OK converted!
  n = finger.fingerFastSearch();
  if (n == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (n == FINGERPRINT_PACKETRECIEVEERR) {
    return n;
  } else if (n == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return n;
    return n;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.print(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (n != FINGERPRINT_OK)  return -1;
  // found a match!
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
  Serial.println("Waiting for valid finger to enroll");
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
      Serial.println(".");
    default:
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
What do you get in seial monitor?
Enrolling working fine, searching keeps looping
Change:
  if(key ==2)
  delay(50);
to:
  if(key ==2)
  do {
    int ret =   getFingerprintIDez();
    delay(50);
  } while (ret < 0);
Same error :slightly_frowning_face:
Try:
  if(key ==2)
  int ret;
  do {
    delay(50);
  } while (ret < 0);
It worked! You're a life saver! THANK YOU :) :)
Did you understand what was the error?
Did you use a return on the whole function?
and why wasn't this necessary with the other function?
In the other function is used too:
Hello, In my project, I have to match the existing template of fingerprint with the same finger which i will input now. My problem is that I cannot understand the matching works in the enroll program.Thats why I am unable to combine the enroll n template programs. Please help! I need a reply in the next 2 days..
Samybawli, did you find some solution?
