Arduino UNO and ADXL345 getting 0 0 0 OR -1 -1 -1 outputs with SPI communication
I have EVAL-ADXL345Z evaluation board from Analog Device hooked up to the Arduino UNO R3, the code complies and runs fine. At first I could still get the output values, but after sometime the output values i get is either 0 0 0 OR -1 -1 -1. Is it any problem with ADXL345 or Arduino UNO? Did I damage the sensor?
Connection:
ADXL345 → Arduino
VIO → 3.3V
GND → GND
CS → Pin 10
VS → 3.3V
SCL → Pin 13
SDA → Pin 11
SDO → Pin12
INT1 → Pin 8
Code:
#include <SPI.h>
#define PINNUMBER
int CS=10;
char values[10];
int x,y,z;
double xg, yg, zg;
char ff=0;
long line = 0;
#define DEVID 0x00 //Device ID Register
#define OFSX 0x1E //X-axis offset
#define OFSY 0x1F //Y-axis offset
#define OFSZ 0x20 //Z-axis offset
#define THRESH_ACT 0x24 //Activity Threshold
#define THRESH_INACT 0x25 //Inactivity Threshold
#define TIME_INACT 0x26 //Inactivity Time
#define ACT_INACT_CTL 0x27 //Axis enable control for activity and inactivity detection
#define THRESH_FF 0x28 //free-fall threshold
#define TIME_FF 0x29 //Free-Fall Time
#define ACT_TAP_STATUS 0x2B //Source of tap/double tap
#define BW_RATE 0x2C //Data rate and power mode control
#define POWER_CTL 0x2D //Power Control Register
#define INT_ENABLE 0x2E //Interrupt Enable Control
#define INT_MAP 0x2F //Interrupt Mapping Control
#define INT_SOURCE 0x30 //Source of interrupts
#define DATA_FORMAT 0x31 //Data format control
#define DATAX0 0x32 //X-Axis Data 0
#define DATAX1 0x33 //X-Axis Data 1
#define DATAY0 0x34 //Y-Axis Data 0
#define DATAY1 0x35 //Y-Axis Data 1
#define DATAZ0 0x36 //Z-Axis Data 0
#define DATAZ1 0x37 //Z-Axis Data 1
void setup(){
SPI.begin();
SPI.setDataMode(SPI_MODE3); //configure accelerometer for SPI connecttion
pinMode(CS, OUTPUT); //set chip select to be output
digitalWrite(CS, HIGH); //set chip select to be high
writeRegister(DATA_FORMAT, 0x03); //put accelerometer into 16G range
writeRegister(POWER_CTL, 0x08); //Measurement mode
void loop(){
readRegister(DATAX0, 6, values);
x = ((int)values[1]<<8)|(int)values[0];
y = ((int)values[3]<<8)|(int)values[2];
z = ((int)values[5]<<8)|(int)values[4];
line = line + 1;
Serial.print(line);
Serial.print(’-’);
Serial.print("X: ");
Serial.print(x, DEC);
Serial.print(’,’);
Serial.print("Y: ");
Serial.print(y, DEC);
Serial.print(’,’);
Serial.print("Z: ");
Serial.print(z, DEC);
Serial.print(’,’);
delay(100);
//convert accelerometer value to G
xg = x * 0.0078;
yg = y * 0.0078;
zg = z * 0.0078;
//Print the results to the terminal so that i can monitor the reading using the serial monitor.
Serial.print("xg: ");
Serial.print((float)xg,2);
Serial.print(“g,”);
Serial.print("yg: ");
Serial.print((float)yg,2);
Serial.print(“g,”);
Serial.print("zg: ");
Serial.print((float)zg,2);
Serial.println(“g”);
delay(100);
// char registerAddress - The register to write a value to
// char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
//Set Chip Select pin low to signal the beginning of an SPI packet.
digitalWrite(CS, LOW); // to signal beginning of SPI packet
SPI.transfer(registerAddress);
SPI.transfer(value);
digitalWrite(CS, HIGH); // to signal end of SPI packet
void readRegister(char registerAddress, int numBytes, char * values){
char address = 0x80 | registerAddress; // to perform read operation the most significant bit of the register address must be set
if(numBytes > 1)address = address | 0x40;
SPI.transfer(address);
for(int i=0; i<numBytes; i++){
values = SPI.transfer(0x00);
  • digitalWrite(CS, HIGH);*
I have had a similar problem. Tried different codes. The last try (I thought the sensor is damaged) switching to I2C was successfull. I think it was the following source: http://bildr.org/2011/03/adxl345-arduino/
May be you can help to solve my problem ;-) http://forum.arduino.cc/index.php?topic=223341.0
Best regards Eicca
