arduino UNO and Arduino mega differences in program
I have the sim900 module and Arduino Uno board and i make the software on arduino Uno and now i connect sim900 module on same pins on arduino mega and upload the same code and some routines work some routine not. do any have same problems and solve it ?
different boards call for different pins.
Nope. I write code in such a ways that it utilizes ONLY the hardware and software that is actually available on the platform it is running on.
and solve it ?
Sure. See above.
If you have some code that doesn't work on both devices, then there is something wrong with your code. POST IT!
I'm going to guess, though, that you are using SoftwareSerial, and haven't bothered to look at the reference page to see that SoftwareSerial can only work on some pins on the Mega. I'm also going to guess that you haven't figured out that the Mega has 4 hardware serial ports, so the necessity of using SoftwareSerial is probably non-existent.
i find the problem because the software serial on sim900 work only on arduino uno (7,8 pins ) and on arduino mega work at TX RX pins now i connect on mega (tx2,rx2) and work good. thank you guys for support :slight_smile:
