Arduino UNO and BLE sheild, with ZBmodule BLE4.0 chip
Hi there,
I’m starting with building up connection between the arduino and PC.
I got a UNO board, a BLE shield, and a ZBmodule chip which is used to bluetooth communication.
I met problems when I tried to use some example codes from the internet, the code is something like the follow,
#if defined(ARDUINO) && ARDUINO >= 100
#  include <Arduino.h>
#else
#  include <WProgram.h>
#endif
#include <Wire.h>
#include <Servo.h>
//#define SOFTUART 1
#define BaudRate 9600
#if defined SOFTUART
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
#endif
Servo servos[6];
uint8_t myservoPin[6]={3,5,6,9,10,11};
String parameter[10];
int arg[10];
volatile uint8_t state=0;
volatile int paraIndex=-1;
uint8_t readData[20];
uint8_t readIndex=0;
unsigned long time;
    Clear the serial receive data
void clearbuff() {
	int i;
	for(i=0;i<8;i++){
		parameter[i] ="";
		arg[i]=0;
	paraIndex=-1;
	state=0;
	ASCII characters into int
void convert(){
	int i;
	for(i=1;i<=paraIndex;i++){
		char temp_char[parameter[i].length() + 1];
		parameter[i].toCharArray(temp_char, sizeof(temp_char));
		arg[i-1] = (uint8_t)(atoi(temp_char));
      Servo  Control
void servoCtrl(uint8_t channer, uint8_t value){
	if(channer>6) return;
	uint8_t pin=channer+1;
	mySerial.print("ServoControl:");
	mySerial.print(",");
	mySerial.print(pin);
	mySerial.println(value);
#endif
	if(!servos[channer-1].attached())
		servos[channer-1].attach(pin);
	servos[channer-1].write(value);
	delay(10);
      Arduino  setup
	Wire.begin();
	Serial.begin(BaudRate);
	mySerial.begin(BaudRate);
	mySerial.println("Hello");
#endif
      Arduino loop
	if(state==1){
		convert();
                mySerial.print("state:");
		mySerial.print(parameter[0]);
		mySerial.print(parameter[1]);
		mySerial.println(parameter[2]);
#endif
		if (parameter[0]=="OFF"){	// Leave ctro
			for(readIndex=0;readIndex<20;readIndex++)
				readData[readIndex]=0;
		if (parameter[0]=="PW"){	// PWM
			if(servos[arg[0]-2].attached())  servos[arg[0]-2].detach();
			pinMode(arg[0], OUTPUT);
			analogWrite(arg[0], arg[1]);
		if (parameter[0]=="SE"){	// Servo
			servoCtrl(arg[0], arg[1]);
		if (parameter[0]=="DL"){	// Dimmer
		if (parameter[0]=="AD"){	// ADC
			float tmp =analogRead(arg[0])*0.0048;
			Serial.print("@AD,");
			Serial.print(arg[0]);
			Serial.print(",");
			Serial.print(tmp);
			Serial.print("\r\n");
			readData[arg[0]+14]=arg[1];
		if (parameter[0]=="OP"){	// OUTPUT
			digitalWrite(arg[0], arg[1]);
			readData[arg[0]]=0;
		if (parameter[0]=="IP"){	// INPUT
			if(arg[1]==1){
				pinMode(arg[0], INPUT);
			}else{
			readData[arg[0]]=arg[1];
        clearbuff();
        // ouput data
	}else if(millis()-time>60){
		time = millis();
		int tmp;
		float adVar;
		while(readData[readIndex]!=1){
			readIndex++;
			if(readIndex>19){
				readIndex=0;
//		mySerial.print("readData:");
//		mySerial.println(readIndex);
#endif
		if(readData[readIndex]==1){
			if(readIndex<14){	//PIN INPUT
				pinMode(readIndex, INPUT);
				tmp =digitalRead(readIndex);
				Serial.print("@IP,");
				Serial.print(readIndex);
				Serial.print(",");
				Serial.print(tmp);
				mySerial.print("@IP,");
				mySerial.print(readIndex);
				mySerial.println(tmp);
				mySerial.print("\r\n");
#endif
			}else{	// ADC
				tmp =readIndex-14;
				adVar =analogRead(tmp)*0.0049;
				Serial.print(tmp);
				Serial.print(",");
				Serial.print(adVar);
			readIndex++;
			if(readIndex>19) readIndex=0;
  SerialEvent occurs whenever a new data comes in the
 hardware serial RX.  This routine is run between each
 time loop() runs, so using delay inside loop can delay
 response.  Multiple bytes of data may be available.
void serialEvent() {
	while (Serial.available()) {
		char inChar = (char)Serial.read();
                if(state==1) return;
		switch(inChar){
			case'@':
				clearbuff();
				paraIndex=0;
			case',':
				paraIndex++;
			case '\n':	//0x0A
				state=1;
				return;
			case '\r':	//0x0D
				state=1;
				return;
			default:
				if(paraIndex>=0&&state==0) parameter[paraIndex] +=inChar;
The module seems not working properly, the device can be found by the android phone with bluetooth 4.0, but it didn’t build up any virtual serial port (pair with device), thus there cannot be any serial data transportation on the bluetooth.
Anyone please point it out for me what was going wrong in this example?
