Arduino Uno and EasyVR
I'm currently, coding a speech recognition robot using arduino and easyvr commander.
Howerver on easy vr commander, when I try to generate arduino code, I get the following error message : no code generation template is available.
How can I fix this, and what does it mean ?
Thank's
Isn't that PC software? That does NOT run on the Arduino. So, you do NOT have an Arduino problem.
And, the fact that you are only now getting started on a complex project, and having problems, does NOT make your problem urgent for us.
How are you connecting the PC to the Arduino?
"The EasyVR Commander software can be used to easily configure your EasyVR module connected to your PC through a QuickUSB cable, an adapter board, or by using the microcontroller host board with the provided “bridge” program (available for ROBONOVA controller board, Arduino, Parallax Basic Stamp)."
PaulS:
Indeed it's not exactly an arduino probleme, but the code that easy vr commander is supposed to generate is a arduino file. On top of that, this place is the only hope for help I have since there is no easyvr community.
PaulS:
It may not be urgent to you but how is this relevant ? Juste pointing the fact that need help as quickly as possible, but the goal is not to make you feel obligated or anything.
johnwasser:
I'm using a QuickUSB cable and I have no issue when I connect the easyvr to the software but when I try to generate the arduino code I need to build my arduino code that doesn't work, and this issue is not mentionned anywhere online and I looked in a lot of places.
Take a deep breath. Calm down. Read that part of your post. See if it makes any sense to you, given that you have not said what happens when you "try to generate the Arduino code", or what happens when you try to compile, link, and upload that code.
Thanks for anyone who answered me, I actually find out how to proceed.
