I am trying to get an Arduino Uno to communicate to an ESP8266. I can get it to work in pass-through mode (using the Serial Monitor), but when I try to upload a sketch to the Arduino to communicate with the ESP8266, I get a series of errors. I have selected "Arduino" from the ESP8266 Boards (3.0.2) to get the ESP8266 library.
Tried various sketches. Here is one:
#include "ESP8266WiFi.h"
const int RSSI_MAX =-50;// define maximum strength of signal in dBm
const int RSSI_MIN =-100;// define minimum strength of signal in dBm
const int displayEnc=1;// set to 1 to display Encryption or 0 not to display
Serial.println("Robojax Wifi Signal Scan");
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(2000);
Serial.println("Setup done");
Serial.println("Wifi scan started");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("Wifi scan ended");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(") ");
Serial.print(WiFi.SSID(i));// SSID
Serial.print(WiFi.RSSI(i));//Signal strength in dBm
Serial.print("dBm (");
Serial.print(dBmtoPercentage(WiFi.RSSI(i)));//Signal strength in %
Serial.print("% )");
if(WiFi.encryptionType(i) == ENC_TYPE_NONE)
Serial.println(" <<***OPEN***>>");
}else{
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
WiFi.scanDelete();
}// loop
* Written by Ahmad Shamshiri
* with lots of research, this sources was used:
* https://support.randomsolutions.nl/827069-Best-dBm-Values-for-Wifi
* This is approximate percentage calculation of RSSI
* WiFi Signal Strength Calculation
* Written Aug 08, 2019 at 21:45 in Ajax, Ontario, Canada
int dBmtoPercentage(int dBm)
int quality;
if(dBm <= RSSI_MIN)
quality = 0;
else if(dBm >= RSSI_MAX)
quality = 100;
quality = 2 * (dBm + 100);
return quality;
}//dBmtoPercentage
Error back is:
Connecting......................................_____
Traceback (most recent call last):
File "C:\Users\brumm\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in
esptool.main(cmdline)
File "C:/Users/brumm/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "C:/Users/brumm/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 529, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
