Hello.
It is recognized by my system but I'm not able to upload anything. The IDE says:
Binary sketch size: 3620 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00Verbose uploading:
/usr/local/arduino/hardware/tools/avr/bin/avrdude -C/usr/local/arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v
-patm ega328p -carduino -P/dev/cuaU2 -b115200 -D -Uflash:w:/var/tmp/build2250459024687948161.tmp/CIRC10_TMP36_Temperature_Sensor.c pp.hex:iavrdude: Version 5.10, compiled on Jul 24 2011 at 07:38:57
Copyright (c) 2007-2009 Joerg WunschSystem wide configuration file is "/usr/local/arduino/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/mic/.avrduderc"
User configuration file does not exist or is not a regular file, skippingUsing Port : /dev/cuaU2
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [00]
avrdude: stk500_getsync(): not in sync: resp=0x00avrdude done. Thank you.
I can upload from Windows 7 machine. Once uploaded I can read data on FreeBSD via Serial Monitor (temperature sensor).
I'm on FreeBSD 8.2-RELEASE-p2 amd64 and Arduino 0022 plus a patch to resolve the readlink problem. I'm using the uarduno kernel module (tried both version 1.00 and 1.02a). I've tried with avrdude standard 5.10 version and also with patch from uarduno - FreeBSD® Kernel Driver for the Arduino Uno
It's recognized as:
ugen0.2: <Arduino (www.arduino.cc)> at usbus0
umodem2: <Arduino (www.arduino.cc) Arduino Uno, class 2/0, rev 1.10/0.01, addr 2 > on usbus0
umodem2: data interface 1, has CM over data, has break
Every time I get the same problem: stk500_getsync(): not in sync: resp=0x00
Any ideas, please?
