Hi.i'm trying to do a communication over ethernet using ENC28J60 and Arduino Uno and run 3 task . I have a little problem with my arduino code. My code is compiling but i get the following error : "Low memory available, stability problems may occur." and the led on the board is blinking very fast. I guess that the board is trying to alocate memory but he faild. Any idea what can i do ?
#include <Arduino_FreeRTOS.h>
#include "HX711.h"
#include <PID_v1.h>
#include <string.h>
//#include <SPI.h>
#include <UIPEthernet.h>
#define configUSE_IDLE_HOOK 0
// FreeRTOS tasks
void TaskPrimaryControlLoop(void *pvParameters);
void TaskConcentrationControlLoop(void *pvParameters);
void TaskIdle(void *pvParameters);
/* Weigth Cells */
#define hx_pf_dout 3
#define hx_pf_clk 2
#define hx_c_dout 5
#define hx_c_clk 4
HX711 pf_scale(hx_pf_dout, hx_pf_clk);
HX711 c_scale(hx_c_dout, hx_c_clk);
float pf_factor = -236000;
float c_factor = -203000;
float p_weigth = 0; // (kg, 0.000) primary liquid weigth
float p_l_weigth = 0; // (kg, 0.000) primary liquid last weigth
float c_weigth = 0; // (kg, 0.000) concentrate liquid weigth
float c_l_weight = 0; // (kg, 0.000) concentrate liquid last weigth
/* h bridge config */
#define speed_p 9
#define forward_p 7
#define backward_p 8
#define speed_c 6
#define forward_c A0
#define backward_c A1
double p_pump = 0; // 0-255 pwm pump output
double c_pump = 0; // 0-255 pwm pump output
//// PID parameters
// Primary Control Loop
#define p_kp 250.0
#define p_ki 25.0
// Concentration Control Loop
#define c_kp 250.0
#define c_ki 25.0
double p_pv = 0; // (%) primary flow value
double c_pv = 0; // (%) concentration flow value
double p_sp = 0; // (l/min) primary flow setpoint
double c_sp_proc = 0; // % concentration
double c_sp = 0; // (l/min) concentration setpoint
PID pid_pcl(&p_pv, &p_pump, &p_sp, p_kp,p_ki,0.0, DIRECT);
PID pid_ccl(&c_pv, &c_pump, &c_sp, c_kp,c_ki,0.0, DIRECT);
/* Communication Ethernet */
#define MAX_STRING_LEN 32
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 2);
IPAddress myDns(192,168,1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
//EthernetClient client;
boolean alreadyConnected = false; // whether or not the client was connected previously
while (!Serial) {
; // wait for serial port to connect. Needed for native USB, on LEONARDO, MICRO, YUN, and other 32u4 based boards.
pinMode(forward_p, OUTPUT);
pinMode(backward_p, OUTPUT);
pinMode(forward_c, OUTPUT);
pinMode(backward_c, OUTPUT);
pinMode(speed_p, OUTPUT);
pinMode(speed_c, OUTPUT);
digitalWrite(backward_p, HIGH);
digitalWrite(backward_c, HIGH);
digitalWrite(forward_p, LOW);
digitalWrite(forward_c, LOW);
pf_scale.set_scale(pf_factor);
c_scale.set_scale(c_factor);
//pf_scale.tare();
//c_scale.tare();
pid_ccl.SetMode(AUTOMATIC);
pid_pcl.SetMode(AUTOMATIC);
xTaskCreate(
, (const portCHAR *)"PrimaryControlLoop" // A name just for humans
, 128 // This stack size can be checked & adjusted by reading the Stack Highwater
, NULL
, 2 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
, NULL );
xTaskCreate(
, (const portCHAR *)"ConcentrationControlLoop" // A name just for humans
, NULL
, NULL );
xTaskCreate(
TaskIdle
, (const portCHAR *)"Idle" // A name just for humans
, 512 // This stack size can be checked & adjusted by reading the Stack Highwater
, NULL
, 0 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
, NULL );
//(void) pvParameters;
for (;;)
p_weigth = pf_scale.get_units(1);
p_pv = (p_l_weigth - p_weigth)*100;
if(p_pv < 0) p_pv = 0;
pid_pcl.Compute();
analogWrite(speed_p, p_pump);
p_l_weigth = p_weigth;
vTaskDelay(200 / portTICK_PERIOD_MS); // 200 ms sample time
for (;;)
c_weigth = c_scale.get_units(1);
c_pv = (c_l_weight - c_weigth)*100;
if(c_pv < 0) c_pv = 0;
c_sp = p_sp * (c_sp_proc/100);
pid_ccl.Compute();
analogWrite(speed_c, c_pump);
c_l_weight = c_weigth;
for(;;){
// when the client sends the first byte, say hello:
if (client) {
if (!alreadyConnected) {
client.flush();
//Serial.println("We have a new client");
//client.println("Hello, client!");
alreadyConnected = true;
recvWithStartEndMarkers();
//showNewData();
if(receivedChars[0] == 's'){
p_sp = atof(subStr(receivedChars, ",", 2));
c_sp_proc = int(subStr(receivedChars, ",", 3));
newData = false;
memset(receivedChars, 0, sizeof(receivedChars));
// send process values to application
if(receivedChars[0] == 'w'){
Serial.print(p_pv);
Serial.print(",");
Serial.print(p_sp);
Serial.print(",");
Serial.print(int(c_pump));
Serial.print(",");
Serial.print(c_pv);
Serial.print(",");
Serial.print(c_sp);
Serial.print(",");
Serial.print(int(p_pump));
newData = false;
// check commands
while(Serial.available() > 7){
p_sp = Serial.parseFloat();
c_sp_proc = Serial.parseInt();
newData = false;
newData = false;
vTaskDelay(1);
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (client.available() > 0 && newData == false) {
rc = client.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
// Function to return a substring defined by a delimiter at an index
char* subStr (char* str, char *delim, int index) {
char *act, *sub, *ptr;
static char copy[MAX_STRING_LEN];
int i;
// Since strtok consumes the first arg, make a copy
strcpy(copy, str);
for (i = 1, act = copy; i <= index; i++, act = NULL) {
//Serial.print(".");
sub = strtok_r(act, delim, &ptr);
if (sub == NULL) break;
return sub;
