Arduino Uno and Getting a stepper motor to move
Hi Folks
What I am trying to do is use a c# application to move a stepper motor using an arduino uno and a DRV8825.
I have written the app, it is connecting to the serial port and sending the word "azleft" through the serial port when I click the button.
private void button5_Click(object sender, EventArgs e)
            serialPort1.WriteLine("azleft");
If I upload this code to the arduino :
/*Example sketch to control a stepper motor with DRV8825 stepper motor driver, AccelStepper library and Arduino: continuous rotation. More info: https://www.makerguides.com */
// Include the AccelStepper library:
#include <AccelStepper.h>
// Define stepper motor connections and motor interface type. Motor interface type must be set to 1 when using a driver:
#define dirPin 2
#define stepPin 3
#define motorInterfaceType 1
String val;
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
  // Set the maximum speed in steps per second:
  stepper.setMaxSpeed(1000);
    // Set the speed in steps per second:
  stepper.setSpeed(400);
  // Step the motor with a constant speed as set by setSpeed():
  stepper.runSpeed();
The stepper motor runs just fine.
So I thought if I changed the above code slightly so it is like this :
#define dirPin 2
#define stepPin 3
String val;
  if(Serial.available())
  val=Serial.readString();
    if (val=="azleft")
  stepper.runSpeed();
Then the motor would only move when I click the button.
However the motor is not moving , I see a light on the arduino flash when I click the button but that is all.
A little help would be appreciated
thanks :slight_smile:
paulr1:
I would suggest that you read Robin2's excellent tutorial Serial Input Basics to see how to receive and parse serial data
hope that helps....
add debug-output to your arduino-code to analyse what the arduino really receives.
#define dirPin 2
#define stepPin 3
String val;
  if (Serial.available()) {
    Serial.println("if(Serial.available() is true");
    val = Serial.readString();
    Serial.print("content of variable val is #");
    Serial.print(val);
    Serial.println("#");
  if (val == "azleft")
    stepper.runSpeed();
best regards Stefan
Change your code with this and run it.
      Serial.print('<');
      Serial.print(val);
      Serial.print('>');
You will see this in serial monitor:
<azleft
That is because serial monitor is sending, 'a','z','l','e','f','t','\r','\n'. That does not = 'a','z','l','e','f','t'.
The '\r' and '\n' are the CR and LF characters sent by serial monitor with the line endings set to Both CR&LF. Change that to No line ending and those characters will not be sent.
And I agree with sherzaad, the serial input basics tutorial shows better ways to receive serial data without using the problematic String class and blocking functions.
Thanks guys , figured it our , changed the app to send a number , then used serial.write instead of writeline and instead of using val=Serial.readString used val=Serial.Parseint.
Seems to work and is doing exactly what I need
:slight_smile:
