Arduino UNO and hc05 not responding after some time
I have made a bluetooth car using Arduino UNO, l298d motor driver and hc05 bluetooth module but when I try to connect my car through the app it works for like 6 to 10 seconds the it automatically stops working. I need to rerun the code the it runs and then again stops. When it stops it should like when I press the forward button the TX pin on Arduino starts blinking very little. I used this tutorial https://youtu.be/tujih1afqiE?si=66d9CMu8Orq-HqRy
https://www.instructables.com/How-to-Make-Bluetooth-Controlled-Car-Using-Arduino/. Here is the link of the website I followed it has circuit diagram and code included in it
That is typical of power supply problems.
Motors must be powered separately from the Arduino and Bluetooth, as the motor electrical noise will often cause the processor to reset. Don't forget to connect all the grounds!
But in the example they use a single batter and powered motor driver and all motors and hc05. Ok I will try thank you so much for replying I will try and give the reports
