Arduino (Uno) and (Mega 2560)
Hi
I have the products above and my project is to build a panel with: potentiometer, Rotary Encorders, on/off and on/off/on toggle switches!
I have solve how I will connect the pots but can I connect the on/off switches acording to:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1263518901/all , reply 12?!
In what way shall I connect the on/off/on switches?
I have read that the cards "Each pin can provide or receive a maximum of 40 mA and has an internal pull-up resistor (disconnected by default) of 20-50 kOhms.
I will save a litte money if I am enable the resistors but is 20kohm too much?
Best Fredrik
The same way, except that the two outside pins (the two on legs) connect to two digital pins.
Not for pullup resistors. What is your concern?
PaulS:
Hi
The switch has a breaking capacity of 12V / 20A but how much power does one switch consume?
I know that the digital pin has 5V and 40mA but does the switch take so much power?
According for my question for the internal pullup resistor, I am wondering if the value of min 20kohm is too much for a switch it maybe need 1kohm, a resistor is a component there theirs value does not change?!
I have ordered the book Getting started with Arduino :slight_smile: so I hope that will help a lot :slight_smile:
Best Fredrik
Switches allow current to flow, or not. They consume only minimal amounts of current - so minimal as to be safely ignored.
The power consumed by the switch would be far less than 1 mA.
No. Thousands of Arduinos happily deal with switches using the internal pullup resistors, and they work just fine.
PaulS:
Too buy a external resistor is waste of money :slight_smile:
I just need too connect the switch snd anable the internal with a code, it cannot be easier than thise :slight_smile:
I have downloaded the program Fritzing and enoy it a lot :slight_smile: But can you test the components virtual? Great if you could test it so you do not burn anything :wink:
Best Fredrik
Look for arduino emulator in google.
H
I am wondering if Rotary Encorder shall be connected in the same way like I connect Rotary potetionmeter?
Does it require more than one analog/digital pin?
Best Fredrik
No.
Yes. 2 digital pins.
http://arduino.cc/playground/Main/RotaryEncoders
Hi
I think I now understand in what way the encorders will be connected :slight_smile:
A encorder has 2 pins an one side and 3 pins on the others. The 2 pins side are handle the push button and the 3 pins side handle the encorder, correct if it wrong!
The middle is the power 5V and the outer pins are the A & B channels that will be connect to the digitals port!
A will also use and enable the internal resistors at the pins how needs it!
Best Fredrik
