userpicture
Buy
Download
Products
Learning
Forum
Support
Blog
LOG IN
SIGN UP
Arduino Forum
> Using Arduino
> Sensors
> Arduino UNO and PIR sensor
Print
Pages: [1]
Topic: Arduino UNO and PIR sensor (Read 192 times) previous topic - next topic
Evgenii_Litvinenko
avatar_Evgenii_Litvinenko
Newbie
[add Karma]
[add Karma]
Mar 18, 2015, 09:32 pm
Hello all.
I'm trying to make alarm system by using PIR sensor when it detects motion buzzer is triggered and astarts to alert. While buzzer is beeping I need to turn it off by using Android Devices BLUETOOTH tool. Now PIR detects motion and triggers buzzer to alert but I can't turn it off bu Android. Here is the code, is there any slack or what I have to do to solve problem? Thanks.
char incomingByte;
int sensor = 8;
pinMode(sensor,INPUT);
pinMode(3,OUTPUT);
if (Serial.available()>0)
incomingByte=Serial.read();
int sensor= 8;
delay (500);
if (digitalRead(sensor) == HIGH)
tone();
if (incomingByte == '8')
digitalWrite(sensor,LOW);
void tone()
tone (3,500,4000);
knut_ny
avatar_knut_ny
Edison Member
[add Karma]
electronics engineer, teacher.
[add Karma]
Re: Arduino UNO and PIR sensor
#1
Mar 23, 2015, 10:18 pm
tips: https://www.youtube.com/watch?v=sXs7S048eIo
Ny
Evgenii_Litvinenko
Newbie
[add Karma]
[add Karma]
#2
Apr 03, 2015, 08:20 pm
Thanks for reply my post. Now I have a new program but I can turn off my buzzer only in first use, after when I receve an ''off'' command from my Android Device it doesn't turning off. Here is code; Why?
char incomingByte;
int val;
int sensor =2;
int ledpin = 13;
pinMode(ledpin = 13, OUTPUT);
pinMode (2, INPUT);
if( Serial.available()>0 )
val = Serial.read();
if( digitalRead (sensor)==HIGH)
tone();
if( val == '8' )
digitalWrite(ledpin = 13, LOW);
Serial.println("13 off");
void tone()
tone (13,500,4000);
try this
int val=0,sensor =2, state = LOW, ledpin = 13;
pinMode(ledpin, OUTPUT);
pinMode (sensor, INPUT);
val = digitalRead(sensor);
if( val==HIGH) {
digitalWrite(ledpin, HIGH);
tone();
if (state == LOW)
{ Serial.println("PIR activated! Led + tone");
state = HIGH;
else { digitalWrite(ledpin, LOW);
noTone(8);
if (state == HIGH) {
Serial.println(" led on pin 13 and buzzer off");
state = LOW;
void tone()
tone (8,500,4000); // hook up your buzzer to pin 8
delay(1000); // how did you get this tone?
after you have done something like this
int sensor =2;
int ledpin= 13;
you just use
ledpin
no need to say
pinMode(ledpin=13, OUTPUT);
I just think the sensor is triggered it is high
if it is not triggered it is low
