Danke für die schnelle Antwort, der Programm Code im Anhang.
#include <RedFly.h>
#include <RedFlyServer.h>
#include <RedFlyClient.h>
#define doorBuzzerPin 7 //Pin for door buzzer
#define errorLedPin 6 //error indicator Led Pin
#define buzzerTime 5 //5s time buzzer
#define udpTime 3 //2s do udp broadcast
#define clientConnectionTestTime 60 //60s do client connetcion test
#define tempPin 0 //analogRead Pin 0
char ssid[] = "xxxx";
char key[]="xxxx";
char router[]="192,168,1,1";
char func[]="d,t";
char ip_all_func_on[120];
char ip_all_func_off[120];
const char action_door_buzzer[] = "door_buzzer";
uint8_t http=INVALID_SOCKET; //socket handle for Client Connect
float actualTemp = 0.0;
uint8_t bytes[4]; //ip adress for the client connect
// Config RedFly
byte ip[4]; //ip adress from RedFly after DHCP connect
byte mac[8]; //mac adress of the shield
//UDP Broadcast ip
byte udpip[] = {255,255, 255, 255 };
//String httpRequest;
char *p_httpRequest;
boolean mustSwitchDoorBuzzerOff = false;
RedFlyClient udpClient(udpip,65000); //UDP Broadcast an Port 65000
RedFlyServer server(80);
int i;
Serial.begin(115000); //init serial port and set baudrate
while(!Serial); //wait for serial port to connect (needed for Leonardo only)
pinMode(doorBuzzerPin, OUTPUT); //door buzzer
pinMode(errorLedPin, OUTPUT); //error indicator
digitalWrite(errorLedPin, LOW);
char *p_router = router;
for ( int i = 0; i < 5; i++ )
bytes[i] = strtol( p_router , &p_router, 10 );
p_router++;
//start WiFi
while(startwifi() != 0){
//init p_httpRequest
p_httpRequest = 0;
unsigned long time;
static unsigned long next_time_router_connect=0;
static unsigned long next_time_udp_call=0;
static unsigned long time_switch_off_buzzer=0;
static uint8_t connection=0;
char tmp[200];
char tempStr[10];
time = millis();
// do door buzzer
//if (httpRequest.indexOf(action_door_buzzer) >0)
if(strstr(p_httpRequest,action_door_buzzer))
debugoutln("Door buzzer switch on");
digitalWrite(doorBuzzerPin, HIGH);
time_switch_off_buzzer = time + (buzzerTime*1000UL);
mustSwitchDoorBuzzerOff = true;
if (time > time_switch_off_buzzer && mustSwitchDoorBuzzerOff)
debugoutln("Door buzzer switch off");
digitalWrite(doorBuzzerPin, LOW); // deactivate door buzzer
//httpRequest = String(); //init http Request String
p_httpRequest = 0;
if(time > next_time_udp_call)
next_time_udp_call = time + (udpTime*1000UL); //every 2s
udpClient.connectUDP();
if(mustSwitchDoorBuzzerOff) udpClient.println(ip_all_func_on);
else udpClient.println(ip_all_func_off);
server.stop();
udpClient.stop();
//client code for connection test
if(time > next_time_router_connect) //connection test every 60s
//new temperature measurement
calculateActualTemperature();
next_time_router_connect = time + (clientConnectionTestTime*1000UL); //every 60s
http = RedFly.socketConnect(PROTO_TCP, bytes, 80); //start connection to the router on port 80
if(http == 0xFF)
debugoutln("client not ok");
RedFly.disconnect();
if(++connection >= 3)
} //restart WiFi module
connection = 0;
debugoutln("client ok");
connection = 0;
//listen for incoming clients
if(server.available()>10)
//a http request ends with a blank line
boolean currentLineIsBlank = true;
while(server.available())
char c = server.read();
*p_httpRequest++ = c;
if(c == '\n' && currentLineIsBlank)
//clear input buffer
server.flush();
//send standard HTTP 200 header
server.print_P(PSTR("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n"));
//send some text
server.println_P(PSTR("<HTML><HEAD><TITEL>RedFly und Arduino </TITEL></HEAD><BODY>"));
server.println_P(PSTR("<table border=0 cellpadding=2 cellspacing=2 with250><tbody><tr>"));
memset(tempStr,0,sizeof(tempStr));
dtostrf( actualTemp, 7, 1, tempStr ); //convert float to char
memset(tmp,0,sizeof(tmp));
sprintf_P(tmp, PSTR("<td>Temp :</td><td>%s</td></tr><tr>"),tempStr);
server.print(tmp);
sprintf_P(tmp, PSTR("<td>Func :</td><td>%s</td></tr></tbody></table></body></html>"), ip_all_func_on);
server.print(tmp);
if(c == '\n')
//you're starting a new line
else if(c != '\r')
//you've gotten a character on the current line
currentLineIsBlank = false;
//close connection
server.stop();
else if(!server.connected()) //listening port still open?
server.stop(); //stop and reset server
server.begin(); //start server
void debugout(char *s)
RedFly.disable();
Serial.print(s);
RedFly.enable();
void debugoutln(char *s)
RedFly.disable();
Serial.println(s);
RedFly.enable();
void calculateActualTemperature()
float temp_all = 0;
for (int i=0;i<10;i++)
temp_all += (analogRead(tempPin)/2)-2;
actualTemp = temp_all/10;
uint8_t startwifi()
uint8_t ret;
char ip_ch[10];
char mac_ch[20];
char *p_ssid = &ssid[0];
char *p_key = &key[0];
//init the WiFi module
if(RedFly.init(115000,HIGH_POWER) != 0) //LOW_POWER MED_POWER HIGH_POWER
digitalWrite(errorLedPin, HIGH);
debugoutln("Fehler 1");
return 1;
//join network the ssid of network must be visible
RedFly.scan();
ret = RedFly.join(p_ssid, p_key, INFRASTRUCTURE);
if(ret)
debugoutln("Fehler ssid key");
return 2;
ret = (RedFly.begin() !=0);
if (ret)
debugoutln("Fehler 3");
return 3;
memset(ip_all_func_on,0,sizeof(ip_all_func_on)); // initialize ip adress, function for udp
memset(ip_all_func_off,0,sizeof(ip_all_func_off));
memset(mac,0,sizeof(mac));
RedFly.getlocalip(ip); //receive shield IP
RedFly.getmac(mac);
for (int i=0;i<6;i++) //build mac adress is used for udp broadcast
memset(ip_ch,0,sizeof(ip_ch));
itoa(mac[i],ip_ch,10);
if(i==0) strcpy(ip_all_func_on,ip_ch);
strcat(ip_all_func_on,ip_ch);
if (i==5) strcat(ip_all_func_on,",");
else strcat(ip_all_func_on,"-");
for (int i=0;i<4;i++) //build ip adress is used for udp broadcast
itoa(ip[i],ip_ch,10);
if (i==3) strcat(ip_all_func_on,",");
else strcat(ip_all_func_on,".");
strcpy(ip_all_func_off,ip_all_func_on);
strcat(ip_all_func_on,"on");
strcat(ip_all_func_on,",2,");
strcat(ip_all_func_on,func);
ip_all_func_on[strlen(ip_all_func_on)] = '\0';
strcat(ip_all_func_off,"off");
strcat(ip_all_func_off,",2,");
strcat(ip_all_func_off,func);
ip_all_func_off[strlen(ip_all_func_off)] = '\0';
server.begin();
return 0;
WebServer.ino (7.52 KB)
