Arduino Uno and Servo motor control
Hi, My friend and I are trying to control 3 LED and 2 Servo motor using Arduino Uno and IR sensor. For LED, we are trying to make each led blink after one minutes (total of three minutes)
After 1 min ->O X X
After 1 min ->O O X
After 1 min ->O O O
Also, the servo motor starts at 0 degree, and when the IR sensor detects an object, the motor turns to 180 degree, wait for 3 minutes and the motor returns to 0 degree. Here is the code we wrote so far.
#include <Servo.h>
Servo servo1, servo2;
int irPin = 7;
int LED1 = 13;
int LED2 = 12;
int LED3 = 11;
int Button = 2;
unsigned long pre_time = 0;
unsigned long now_time = 0;
boolean state = false;
  pinMode(LED1, OUTPUT);  //Timver LED1
  pinMode(LED2, OUTPUT);  //Timer LED2
  pinMode(LED3, OUTPUT);  //Timer LED3
  pinMode(irPin, INPUT);  //IR sensor
  pinMode(Button, INPUT_PULLUP); //Button
  servo1.attach(9);       //Servo1
  servo2.attach(10);      //Servo2
  attachInterrupt(digitalPinToInterrupt(Button), exchange, FALLING);
  int value = digitalRead(irPin);
  now_time = millis();
  if(value == HIGH)
    if(now_time - pre_time > 100)
      servo1.write(0);
      servo2.write(180);
      pre_time = now_time = 0;
      digitalWrite(LED1, LOW);
      digitalWrite(LED2, LOW);
      digitalWrite(LED3, LOW);
  if(state = false)
    if(value == LOW)
        servo1.write(80);
        servo2.write(110);
      if(now_time - pre_time > 6000)
        digitalWrite(LED1, HIGH);
        digitalWrite(LED2, HIGH);
        digitalWrite(LED3, HIGH);
      if(now_time - pre_time > 2000)
        servo1.write(0);
        servo2.write(180);
The problem is we want the motor to stay at 0 degree after three minutes, but the motor go back to 180 degree. How should I modify the code so that after three minutes, motor turns to 0 degree and wait tot trun 180 until the IR sensor detects another object?
Proper use of code tags on your first post. YAY! Karma++
Give me a moment to review your code
Edit:
this bothers me.
What are you trying to do?
This bothers me
What do you need an interrupt for?
Where is the handling routine (I think you want one names 'exchange')
Edit2:
You use state, but only initialize it to fals and then never change it.
What are you trying to do with state?
You have 2 independent cycles.
  1. LEDs change every second.
  2. Servos move in response to the IS sensor.
    Right?
    I would think that it would be appropriate to have a different time tracking variable for each.
    It looks to me like you are trying to use pre_time for both.
If I were trying to make this work, I would tackle the 2 pieces separately.
Male the LEDs blink the way you want (further kudos for using millis)
In a different sketch, I would make the sensor and servos work the way I want.
Then I would try to combine them.
Edit3:
You mentioned one second intervals for the LEDs. But I see you using 100 millis. That is only one tenth of a second.
vinceherman:
this bothers me.
Google tells me that this is a valid way to set multiple variables.
It still bothers me but that is just a style thing.
Carry on.
