Hello. Im trying to get a higher torque servo to work with my Uno, but cant seem to figure it out. Below are pictures of my setup. Smaller servo plugs into Arduino, and runs a loop with no problems. Bigger servo connected directly to 4 AA batteries and yellow wire into port 9, servo wont move. Any thoughts?
Your second picture has no ground connection to the Uno.
Thank you! Do you have any idea how I can ground it?
Connect the black wire from the battery to a pin marked "Gnd" on the Uno, and to the servo.
That did it. Thank you so much.
Im going to further complicate this by trying to connect a light sensor so that when the light sensor detects light, the servo will open, and then when the light goes out, the servo will close. Can I do that on th board or do I need to use a breadboard? Im still new to Arduino, only had it for 3 days.
You should get a solderless breadboard and/or prototyping PCBS.
You can use a LDR without a breadboard (connect directly to the Uno) by using the internal pullup on the analog input as the LDR load resistor if the sensitivity is OK.
const byte ldrPin = A0;
// enable internal pullup on pin A0
pinMode(ldrPin, INPUT_PULLUP);
static unsigned long timer = 0;
unsigned long interval = 1000;
if (millis() - timer >= interval)
timer = millis();
int ldrValue = analogRead(ldrPin);
Serial.print("Light reading = ");
Serial.println(ldrValue);
Just connect the black wire from the battery adapter to any ground pin on the board.
