Hi everybody,
I am new in Arduino and I just buy a Sparkfun ESP8266 WiFi Shield to connect an Arduino UNO to WiFi and I'm using an example which is with the library os SparkFunESP8266WiFi with this code:
#include <SoftwareSerial.h>
#include <SparkFunESP8266WiFi.h>
const char mySSID[] = "yourSSIDhere";
const char myPSK[] = "yourPWDhere";
ESP8266Server server = ESP8266Server(80);
const char destServer[] = "example.com";
const String htmlHeader = "HTTP/1.1 200 OK\r\n"
"Content-Type: text/html\r\n"
"Connection: close\r\n\r\n"
"<!DOCTYPE HTML>\r\n"
"<html>\r\n";
const String httpRequest = "GET / HTTP/1.1\n"
"Host: example.com\n"
"Connection: close\n\n";
serialTrigger(F("Press any key to begin."));
initializeESP8266();
connectESP8266();
displayConnectInfo();
serialTrigger(F("Press any key to connect client."));
clientDemo();
serialTrigger(F("Press any key to test server."));
serverSetup();
serverDemo();
void initializeESP8266()
int test = esp8266.begin();
if (test != true)
Serial.println(F("Error talking to ESP8266."));
errorLoop(test);
Serial.println(F("ESP8266 Shield Present"));
void connectESP8266()
int retVal = esp8266.getMode();
if (retVal != ESP8266_MODE_STA)
retVal = esp8266.setMode(ESP8266_MODE_STA);
if (retVal < 0)
Serial.println(F("Error setting mode."));
errorLoop(retVal);
Serial.println(F("Mode set to station"));
retVal = esp8266.status();
if (retVal <= 0)
Serial.print(F("Connecting to "));
Serial.println(mySSID);
retVal = esp8266.connect(mySSID, myPSK);
if (retVal < 0)
Serial.println(F("Error connecting"));
errorLoop(retVal);
void displayConnectInfo()
char connectedSSID[24];
memset(connectedSSID, 0, 24);
int retVal = esp8266.getAP(connectedSSID);
if (retVal > 0)
Serial.print(F("Connected to: "));
Serial.println(connectedSSID);
IPAddress myIP = esp8266.localIP();
Serial.print(F("My IP: ")); Serial.println(myIP);
void clientDemo()
ESP8266Client client;
int retVal = client.connect(destServer, 80);
if (retVal <= 0)
Serial.println(F("Failed to connect to server."));
return;
client.print(httpRequest);
while (client.available())
Serial.write(client.read()); // read() gets the FIFO char
if (client.connected())
client.stop(); // stop() closes a TCP connection.
void serverSetup()
server.begin();
Serial.print(F("Server started! Go to "));
Serial.println(esp8266.localIP());
void serverDemo()
ESP8266Client client = server.available(500);
if (client)
Serial.println(F("Client Connected!"));
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
if (c == '\n' && currentLineIsBlank)
Serial.println(F("Sending HTML page"));
client.print(htmlHeader);
String htmlBody;
for (int a = 0; a < 6; a++)
htmlBody += "A";
htmlBody += String(a);
htmlBody += ": ";
htmlBody += String(analogRead(a));
htmlBody += "
\n";
htmlBody += "</html>\n";
client.print(htmlBody);
if (c == '\n')
else if (c != '\r')
currentLineIsBlank = false;
delay(1);
client.stop();
Serial.println(F("Client disconnected"));
void errorLoop(int error)
Serial.print(F("Error: ")); Serial.println(error);
Serial.println(F("Looping forever."));
for (;;)
void serialTrigger(String message)
Serial.println(message);
while (!Serial.available())
while (Serial.available())
Serial.read();
But I get the following answer
Error: 0
Looping forever.
What is bad in this sketch? Why doesn't work? Is anything wrong with the conecction of the Arduino and the Spakfun ESP8266 WiFi Shield?
Thanks for all and your help
Best Regards
