Sorry Nick, I have copied-pasted the IP from the example too fast and forgot to modify it to my IP.... :~
Now testing a bit more, I have discovered that I need to connect the arduino to my computer via USB to be able to either ping or access the webserver... If I unplug the USB cable, everything still works fine..
Must be in my code.
The code I am using for the thermometer
* OnlineThermometer
* Reads values from DS18B20 1-wire temperature sensors and displays
* the current readings in a web page. This version is designed to work
* with Ethernet shields based on the Wiznet W5100 chipset, including
* the official Arduino Ethernet shield and also the Freetronics
* Ethernet shield with PoE support:
* www.freetronics.com/ethernet-shield
* This sketch requires the "Webduino" library, available from:
* code.google.com/p/webduino
* Copyright 2009-2010 Jonathan Oxer <jon@oxer.com.au>
* www.practicalarduino.com/projects/online-thermometer
* www.freetronics.com/pages/online-thermometer
#include <SPI.h>
#include <Ethernet.h>
#include <WebServer.h>
// No-cost stream operator as described at
// http://sundial.org/arduino/?page_id=119
template<class T>
inline Print &operator <<(Print &obj, T arg)
{ obj.print(arg); return obj; }
// Modify the following lines to suit your local network configuration.
// The MAC and IP address have to be unique on your LAN:
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
static uint8_t ip[] = { 192, 168, 0, 109 };
static uint8_t myPort = 80; // Listen port for tcp/www (range 1-254)
/* This creates an instance of the webserver. By specifying a prefix
* of "/", all pages will be at the root of the server. */
#define PREFIX ""
WebServer webserver( PREFIX, myPort );
// Specify data pins for connected DS18B20 temperature sensors
#define SENSOR_A 14
#define SENSOR_B 15
#define SENSOR_C 16
#define SENSOR_D 17
#define SENSOR_E 18
#define SENSOR_F 19
// Function prototypes to trick the Arduino pre-processor into
// allowing call-by-reference
void sendTemperatureValues( WebServer &server);
void sendAboutPage( WebServer &server);
void sendFormButtons( WebServer &server);
* Default page to return to browser
void valuesCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
server.httpSuccess();
sendTemperatureValues( server );
sendFormButtons( server );
void aboutCmd(WebServer &server, WebServer::ConnectionType type, char *url_tail, bool tail_complete)
sendAboutPage( server );
* Configure Ethernet shield
void setup(){
Serial.begin(38400);
Ethernet.begin(mac, ip);
webserver.begin();
webserver.setDefaultCommand( &valuesCmd );
webserver.addCommand( "values", &valuesCmd );
webserver.addCommand( "about", &aboutCmd );
// Set up the data pins for communication with DS18B20 sensors
digitalWrite(SENSOR_A, LOW);
pinMode(SENSOR_A, INPUT);
digitalWrite(SENSOR_B, LOW);
pinMode(SENSOR_B, INPUT);
digitalWrite(SENSOR_C, LOW);
pinMode(SENSOR_C, INPUT);
digitalWrite(SENSOR_D, LOW);
pinMode(SENSOR_D, INPUT);
digitalWrite(SENSOR_E, LOW);
pinMode(SENSOR_E, INPUT);
* Main program loop
void loop(){
webserver.processConnection();
* Send the HTML for the "about" page
void sendAboutPage( WebServer &server )
server.print("<h1>Online Thermometer v1.0 (Wiznet W5100 version)</h1>");
* Send the HTML for the navigation buttons
void sendFormButtons( WebServer &server )
// Display a form button to update the display
server << "<p><form METHOD='POST' action='" PREFIX "/values'>";
server.println("<input type=submit value=\"Refresh Data\">");
server.println("</form></p>");
// Display a form button to access the "about" page
server << "<p><form METHOD=POST action='" PREFIX "/about'>";
server.println("<input type=submit value=\"About the thermometer\">");
server.println("</form>");
* Get temperature values from connected sensors and generate the HTML
void sendTemperatureValues( WebServer &server )
char temp_string_a[10];
char temp_string_b[10];
char temp_string_c[10];
char temp_string_d[10];
char temp_string_e[10];
char temp_string_f[10];
getCurrentTemp(SENSOR_A, temp_string_a);
getCurrentTemp(SENSOR_B, temp_string_b);
getCurrentTemp(SENSOR_C, temp_string_c);
getCurrentTemp(SENSOR_D, temp_string_d);
getCurrentTemp(SENSOR_E, temp_string_e);
getCurrentTemp(SENSOR_F, temp_string_f);
server.print("Sensor A:");
server.print(temp_string_a);
server.print("
server.print("Sensor B:");
server.print(temp_string_b);
server.print("
server.print("Sensor C:");
server.print(temp_string_c);
server.print("
server.print("Sensor D:");
server.print(temp_string_d);
server.print("
server.print("Sensor E:");
server.print(temp_string_e);
server.print("
server.print("Sensor F:");
server.print(temp_string_f);
server.print("
* Reset the 1-wire bus
void OneWireReset (int Pin) // reset. Should improve to act as a presence pulse
digitalWrite (Pin, LOW);
pinMode (Pin, OUTPUT); // bring low for 500 us
delayMicroseconds (500);
pinMode (Pin, INPUT);
* Send data to a 1-wire device
void OneWireOutByte (int Pin, byte d) // output byte d (least sig bit first).
byte n;
for (n=8; n!=0; n--)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds (5);
delayMicroseconds (60);
d = d>>1; // now the next bit is in the least sig bit position.
* Read data from a 1-wire device
byte OneWireInByte (int Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead (Pin);
delayMicroseconds (50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return (d);
* Read temperature from a DS18B20.
* int sensorPin: Arduino digital I/O pin connected to sensor
* char *temp: global array to be populated with current reading
void getCurrentTemp (int sensorPin, char *temp)
int HighByte, LowByte, TReading, Tc_100, sign, whole, fract;
OneWireReset (sensorPin);
OneWireOutByte (sensorPin, 0xcc);
OneWireOutByte (sensorPin, 0x44); // Perform temperature conversion, strong pullup for one sec
OneWireOutByte (sensorPin, 0xbe);
LowByte = OneWireInByte (sensorPin);
HighByte = OneWireInByte (sensorPin);
TReading = (HighByte << 8) + LowByte;
sign = TReading & 0x8000; // test most sig bit
if (sign) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's complement
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
whole = Tc_100 / 100; // separate off the whole and fractional portions
fract = Tc_100 % 100;
if (sign) {
temp[0] = '-';
temp[0] = '+';
if (whole/100 == 0) {
temp[1] = ' ';
temp[1] = whole/100+'0';
temp[2] = (whole-(whole/100)*100)/10 +'0' ;
temp[3] = whole-(whole/10)*10 +'0';
temp[4] = '.';
temp[5] = fract/10 +'0';
temp[6] = fract-(fract/10)*10 +'0';
temp[7] = '\0';
