Arduino Uno as a HID Keyboard PROBLEM
PaulS:
  if (digitalRead(switchPin) == LOW)  // check if button was pressed
   buttonPresses++;                  // increment buttonPresses count
   delay(600);                       // debounce switch
You do NOT want to increment the counter when the pin IS low. You want to increment when the pin BECOMES low. Look at the state change detection example.
A 600 millisecond delay is not debouncing.
But I have the Pin set high if the button is not pressed. so Why it should not be counted when its low?
600ms is because I don't want to allow the button being pressed that frequently.
I will try to send text to confirm if the connection works.
Oh I tried this code. Its a random Key/ Random Delay. And this worked.
/* Arduino USB HID Keyboard Demo
 * Random Key/Random Delay
uint8_t buf[8] = {
  0 }; 	/* Keyboard report buffer */
  randomSeed(analogRead(0));
  delay(200);
  int randomChar = random(4, 130);
  long randomDelay = random(1000, 10000);
  delay(randomDelay);
  buf[2] = randomChar;	  // Random character
  Serial.write(buf, 8);	// Send keypress
  releaseKey();
void releaseKey()
  buf[0] = 0;
  buf[2] = 0;
  Serial.write(buf, 8);	// Release key
