I am using an Arduino UNO R3 to verify+upload an empty sketch. It should just upload the sketch, that essentially does nothing. However, the message below is what I get. Any hints why this happens?? Thanks in advance, AA
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
The program actually uploaded consists of the standard initialization of the timers and the ADC to prepare for millis(), micros(), analogWrite() and analogRead(), followed by your function setup(), which is empty, and will enter an infinite loop executing your function loop(), also empty.
The last line: avrdude done. Thank you. means the sketch is uploaded normally and your board is now executing your program, that does nothing.
Only if it's the last line This is an attempt to upload a sketch to a Mega while the selected board is a Nano (IDE 2.x)
System wide configuration file is "C:\Users\Wim\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xec
avrdude: stk500_getsync(): can't communicate with device: resp=0xeb
Failed uploading: uploading error: exit status 1
This was purely done to demonstrated that avrdude done. Thank you. is not the whole story
It's not really the processor, it's the bootloader. This demonstrates uploading to an Uno with the Nano as the board (using old bootloader); same processor
Using Port : COM7
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x37
