Hi been struggeling whit this porsject all day.
I am trying as my first arduino prosject to make a rc car whit a servo.
I made this:Cxemcar (by following this: control rc car smartphone)
That worked, but then I added a servo and started to tinker around a little,
Added this at the right places to see it it would work:
Arduino Servo Test sketch
#include <Servo.h>
Servo servoMain; // Define our Servo
servoMain.attach(10); // servo on digital pin 10
servoMain.write(45); // Turn Servo Left to 45 degrees
delay(1000); // Wait 1 second
servoMain.write(67.5); // Turn Servo Left to 67.5 degrees
servoMain.write(90); // Turn Servo back to center position (90 degrees)
servoMain.write(112.5); // Turn Servo Right to 112.5 degrees
servoMain.write(135); // Turn Servo Right to 135 degrees
I only made the servo work, the rest of the code is as it never was there. This is the total code that I wrote:
[table][tr][td]#include "EEPROM.h"
#define D1 2 // direction of motor rotation 1
#define M1 3 // PWM left motor
#define D2 4 // direction of motor rotation 2
#define M2 5 // PWM right motor
#define HORN 13 // additional channel 1
#include <Servo.h>
Servo servo; // Define our Servo
//#define autoOFF 2500 // milliseconds after which the robot stops when the connection
#define cmdL 'L' // UART-command for left motor
#define cmdR 'R' // UART-command for right motor
#define cmdH 'H' // UART-command for additional channel (for example Horn)
#define cmdF 'F' // UART-command for EEPROM operation
#define cmdr 'r' // UART-command for EEPROM operation (read)
#define cmdw 'w' // UART-command for EEPROM operation (write)
char incomingByte; // incoming data
char L_Data[4]; // array data for left motor
byte L_index = 0; // index of array L
char R_Data[4]; // array data for right motor
byte R_index = 0; // index of array R
char H_Data[1]; // array data for additional channel
byte H_index = 0; // index of array H
char F_Data[8]; // array data for EEPROM
byte F_index = 0; // index of array F
char command; // command
unsigned long currentTime, lastTimeCommand, autoOFF;
Serial.begin(9600); // initialization UART
servo.attach(10); // servo on digital pin 10
pinMode(HORN, OUTPUT); // additional channel
pinMode(D1, OUTPUT); // output for motor rotation
pinMode(D2, OUTPUT); // output for motor rotation
/*EEPROM.write(0,255);
EEPROM.write(1,255);
EEPROM.write(2,255);
EEPROM.write(3,255);*/
timer_init(); // initialization software timer
void timer_init() {
uint8_t sw_autoOFF = EEPROM.read(0); // read EEPROM "is activated or not stopping the car when losing connection"
if (sw_autoOFF == '1') { // if activated
char var_Data[3];
var_Data[0] = EEPROM.read(1);
var_Data[1] = EEPROM.read(2);
var_Data[2] = EEPROM.read(3);
autoOFF = atoi(var_Data) * 100; // variable autoOFF ms
else if (sw_autoOFF == '0') {
autoOFF = 999999;
else if (sw_autoOFF == 255) {
autoOFF = 2500; // if the EEPROM is blank, dafault value is 2.5 sec
currentTime = millis(); // read the time elapsed since application start
if (Serial.available() > 0) { // if received UART data
incomingByte = Serial.read(); // raed byte
if (incomingByte == cmdL) { // if received data for left motor L
command = cmdL; // current command
memset(L_Data, 0, sizeof(L_Data)); // clear array
L_index = 0; // resetting array index
else if (incomingByte == cmdR) { // if received data for left motor R
command = cmdR;
memset(R_Data, 0, sizeof(R_Data));
R_index = 0;
else if (incomingByte == cmdH) { // if received data for additional channel
command = cmdH;
memset(H_Data, 0, sizeof(H_Data));
H_index = 0;
else if (incomingByte == cmdF) { // if received data for EEPROM op
command = cmdF;
memset(F_Data, 0, sizeof(F_Data));
F_index = 0;
else if (incomingByte == '\r') command = 'e'; // end of line
else if (incomingByte == '\t') command = 't'; // end of line for EEPROM op
if (command == cmdL && incomingByte != cmdL) {
L_Data[L_index] = incomingByte; // store each byte in the array
L_index++; // increment array index
else if (command == cmdR && incomingByte != cmdR) {
R_Data[R_index] = incomingByte;
R_index++;
else if (command == cmdH && incomingByte != cmdH) {
H_Data[H_index] = incomingByte;
H_index++;
else if (command == cmdF && incomingByte != cmdF) {
F_Data[F_index] = incomingByte;
F_index++;
else if (command == 'e') { // if we take the line end
Control4WD(atoi(L_Data), atoi(R_Data), atoi(H_Data));
delay(10);
else if (command == 't') { // if we take the EEPROM line end
Flash_Op(F_Data[0], F_Data[1], F_Data[2], F_Data[3], F_Data[4]);
lastTimeCommand = millis(); // read the time elapsed since application start
if (millis() >= (lastTimeCommand + autoOFF)) { // compare the current timer with variable lastTimeCommand + autoOFF
Control4WD(0, 0, 0); // stop the car
servo.write(45); // Turn Servo Left to 45 degrees
servo.write(67.5); // Turn Servo Left to 67.5 degrees
servo.write(90); // Turn Servo back to center position (90 degrees)
servo.write(112.5); // Turn Servo Right to 112.5 degrees
servo.write(135); // Turn Servo Right to 135 degrees
void Control4WD(int mLeft, int mRight, uint8_t Horn) {
bool directionL, directionR; // direction of motor rotation L298N
byte valueL, valueR; // PWM M1, M2 (0-255)
if (mLeft > 0) {
valueL = mLeft;
directionL = 0;
else if (mLeft < 0) {
valueL = 255 - abs(mLeft);
directionL = 1;
else {
directionL = 0;
valueL = 0;
if (mRight > 0) {
valueR = mRight;
directionR = 0;
else if (mRight < 0) {
valueR = 255 - abs(mRight);
directionR = 1;
else {
directionR = 0;
valueR = 0;
analogWrite(M1, valueL); // set speed for left motor
analogWrite(M2, valueR); // set speed for right motor
digitalWrite(D1, directionL); // set direction of left motor rotation
digitalWrite(D2, directionR); // set direction of right motor rotation
digitalWrite(HORN, Horn); // additional channel
void Flash_Op(char FCMD, uint8_t z1, uint8_t z2, uint8_t z3, uint8_t z4) {
if (FCMD == cmdr) { // if EEPROM data read command
Serial.print("FData:"); // send EEPROM data
Serial.write(EEPROM.read(0)); // read value from the memory with 0 address and print it to UART
Serial.write(EEPROM.read(1));
Serial.write(EEPROM.read(2));
Serial.write(EEPROM.read(3));
Serial.print("\r\n"); // mark the end of the transmission of data EEPROM
else if (FCMD == cmdw) { // if EEPROM data write command
EEPROM.write(0, z1); // z1 record to a memory with 0 address
EEPROM.write(1, z2);
EEPROM.write(2, z3);
EEPROM.write(3, z4);
timer_init(); // reinitialize the timer
Serial.print("FWOK\r\n"); // send a message that the data is successfully written to EEPROM
I do want to make my own android app to controll this but haven't gotten that far in the project yet, but was hoping to use this app in the mean while: Google Appstore
Anyone who can help me do this?
