Arduino Uno + Bluetooth Bee + XBee Shield V1.1 connection problems
Good day,
I have managed to set up my Bluetooth bee by sending the setup data via SSCOM 3.2 but when I use code to send the data, the Bluetooth bee does not get set up. The code I am using is from the Bluetooth bee wiki:
BluetoothBee Demo Code - Flowcontrol Based Implementation
2010,2011 Copyright (c) Seeed Technology Inc.  All right reserved.
Author: Visweswara R
This demo code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
For more details about the product please check http://www.seeedstudio.com/depot/
/* Upload this sketch to Seeeduino and press reset*/
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 11
#define TxD 12
#define DEBUG_ENABLED  1
SoftwareSerial blueToothSerial(RxD,TxD);
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    setupBlueToothConnection();
  //Typical Bluetoth command - response simulation:
  //Type 'a' from PC Bluetooth Serial Terminal
  //See Bluetooth Bee - Wiki for instructions
  if(blueToothSerial.read() == 'a')
    blueToothSerial.println("You are connected");
    //You can write you BT communication logic here
void setupBlueToothConnection()
    blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
    sendBlueToothCommand("\r\n+STWMOD=0\r\n");
    sendBlueToothCommand("\r\n+STNA=SeeeduinoBluetooth\r\n");
    sendBlueToothCommand("\r\n+STAUTO=0\r\n");
    sendBlueToothCommand("\r\n+STOAUT=1\r\n");
    sendBlueToothCommand("\r\n +STPIN=0000\r\n");
    delay(2000); // This delay is required.
    sendBlueToothCommand("\r\n+INQ=1\r\n");
//Checks if the response "OK" is received
void CheckOK()
  char a,b;
  while(1)
    if(blueToothSerial.available())
    a = blueToothSerial.read();
    if('O' == a)
      // Wait for next character K. available() is required in some cases, as K is not immediately available.
      while(blueToothSerial.available())
         b = blueToothSerial.read();
      if('K' == b)
  while( (a = blueToothSerial.read()) != -1)
    //Wait until all other response chars are received
void sendBlueToothCommand(char command[])
    blueToothSerial.print(command);
    CheckOK();
However nothing seems to get sent to the terminal. I have tried to use a ton of other code even setting up the bluetooth bee and just sending the +INQ line, nothing seems to work.
Could someone help me with this?
Thank you!
