About master/slave, as you think your module is master there is simple way check it. can you look tracks or measure where status led on your btmodule is connected. if it's connected to pin 24 of module it then have hc04 firmware and its slave only. if led goes pin 31 or 32 then hc05 firmware and it can be master or slave.
to find right pins, tx and rx are 1 adn 2 and opposite side last pin is 34
pin 1 is also marked with white point
If its hc04 its ok for you as its slave and default baudrate is 9600, but if its hc05 you can change it to slave sending AT+ROLE=0\r\n command from arduino or terminal via tx/rx pins. before that you must put it in at mode by setting pin 34 of module to high state, dont use 5v but 3.3v for this, and powerup it. its now in at mode and baudrate must be now 38400.
when paired defaul baudrate for both is 9600.
you can also test ttl serial communication by sending AT (for hc04) or AT\r\n(hc05), module should reply OK, you can use led off/on to show ok reply.
Other thing, that module have onboard regulator so it can be connected to 5v, but rx and tx are still 3.3v tolerant. im not sure about atmel chips(i use schottky & pullup) but some other cases ttl serial communication is not working if it is connected to 5v logic. i suggest to add atleast resistor(maybe 1k)from arduino tx to module rx line.
hope that help you or someone else if your module is wrong mode.
