Arduino Uno + Bluetooth Mate - Can't transmit from Bluetooth
All,
I have an Arduino Uno and a Bluetooth module hooked together like this: http://www.wateb.com/arduino-uno-bluetooth-mate-gold/
I am able to pair the bluetooth module with my Mac with no issues. I loaded this code on the arduino:
#include <SoftwareSerial.h>
int bluetoothTx = 2;
int bluetoothRx = 3;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  //Setup usb serial connection to computer
  //Setup Bluetooth serial connection to android
  bluetooth.begin(115200);
  bluetooth.print("$$");
  delay(100);
  bluetooth.println("U,9600,N");
  bluetooth.begin(9600);
  //Read from bluetooth and write to usb serial
  if(bluetooth.available())
    char toSend = (char)bluetooth.read();
    Serial.print(toSend);
  //Read from usb serial to bluetooth
  if(Serial.available())
    char toSend = (char)Serial.read();
    bluetooth.print(toSend);
When using this code, I am able to type strings in on the serial console and they are transmitted to the bluetooth console. However, when I type strings in to the bluetooth console, they are NOT transmitted to the serial console.
I am using CoolTerm for Mac. I've also tried Putty on the PC with no luck. My bluetooth connection settings are:
Baudrate:115200
Data bits: 8
Parity: none
Stop bits: 1
Flow control: off
DTR: on
RTS: on
Again, I am able to transmit from serial -> bluetooth with no issues, but bluetooth->serial is not working at all :frowning:
Does anyone have any advice on how to fix this? I'm quite new to Arduino, but definitely not a novice in programming.
Thanks!
Kevin
As a quick check you can connect the rx and tx pins on the Bluetooth mate together, connect it in cool term and send a few characters. That will just confirm that it is sending and receiving properly. Apart from that, I can't see anything obviously wrong with your code
