Dear community,
why the functions doesnt work?
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Net;
using System.Net.NetworkInformation;
using System.Linq;
using System.IO.Ports;
using System.Text;
using System.Diagnostics;
using System.Globalization;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace WindowsFormsApp1
public partial class Form1 : Form
string serialDataIn;
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
button_open.Enabled = true;
button_close.Enabled = false;
button_send.Enabled = false;
progressBar_status.Value = 0;
label_status.Text = "DISCONNECTED";
label_status.ForeColor = Color.Red;
comboBox_BAUD.Text = "9600";
string[] portLists = SerialPort.GetPortNames();
comboBox_COM.Items.AddRange(portLists);
private void button_open_Click(object sender, EventArgs e)
try
serialPort1.PortName = comboBox_COM.Text;
serialPort1.BaudRate = Convert.ToInt32(comboBox_BAUD.Text);
serialPort1.Open();
button_open.Enabled = false;
button_close.Enabled = true;
button_send.Enabled = true;
progressBar_status.Value = 100;
label_status.Text = "CONNECTED";
label_status.ForeColor = Color.Green;
DateTime localDate = DateTime.Now;
DateTime utcDate = DateTime.UtcNow;
String[] cultureNames = { "de-DE" };
foreach (var cultureName in cultureNames)
var culture = new CultureInfo(cultureName);
richTextBox_text.AppendText(Environment.NewLine + " Local date and time: " +
localDate.ToString(culture) + " " + localDate.Kind + " --|| Nemesis started... ||");
richTextBox_text.AppendText(Environment.NewLine + " Enter h to display menu...");
catch (Exception error)
MessageBox.Show(error.Message);
private void button_close_Click(object sender, EventArgs e)
if (serialPort1.IsOpen)
try
serialPort1.Close();
private void Form1_FormClosing(object sender, FormClosingEventArgs e)
try
private void button_send_Click(object sender, EventArgs e)
try
serialPort1.Write(textBox_input.Text + "#");
private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
serialDataIn = serialPort1.ReadExisting();
_ = this.Invoke(new EventHandler(ShowData));
private void ShowData(object sender, EventArgs e)
richTextBox_text.Text += serialDataIn;
if (serialDataIn == "1") // This function dosent work , but worked a few minutes before...
richTextBox_text.AppendText(" Local date and time: " + localDate.ToString(culture) + " <-->" + localDate.Kind + " --|| TIME ||");
//serialPort1.Write(localDate.ToString(culture) + localDate.Kind);
else if (serialDataIn == "2") // This function dosent work too
richTextBox_text.AppendText(Environment.NewLine + localDate.ToString(culture) + " Ping");
try
Ping myPing = new Ping();
PingReply reply = myPing.Send("www.google.de", 1000);
if (reply != null)
richTextBox_text.AppendText(Environment.NewLine + "Status : " + reply.Status + Environment.NewLine + " \n Time : " + reply.RoundtripTime.ToString() + Environment.NewLine + " \n Address : " + reply.Address);
richTextBox_text.AppendText(reply.ToString());
serialPort1.Write(reply.ToString());
serialPort1.Write("Status : " + reply.Status + " \n Time : " + reply.RoundtripTime.ToString() + " \n Address : " + reply.Address);
catch
richTextBox_text.AppendText(Environment.NewLine + "ERROR: You have Some TIMEOUT issue");
private void richTextBox_text_TextChanged(object sender, EventArgs e)
richTextBox_text.SelectionStart = richTextBox_text.Text.Length;
richTextBox_text.ScrollToCaret();
private void start_1_Click(object sender, EventArgs e)
Process.Start("C:\\Program Files (x86)\\Arduino\\arduino.exe");
private void start_2_Click(object sender, EventArgs e)
Process.Start("D:\\Programme (x86)\\arduino-nightly-windows\\arduino-nightly\\arduino.exe");
private void start_3_Click(object sender, EventArgs e)
Process.Start("C:\\Users\\cl0ud\\AppData\\Local\\Programs\\Arduino IDE\\Arduino IDE.exe");
private void openfolder_btn_Click(object sender, EventArgs e)
Process.Start("explorer.exe", @"C:\Users\cl0ud\.Nemesis");
// Author: BlackLeakz
// Date: 18.05.2022
// Time: 0732
// Website: https://blackzspace.org
// Version: 1
// 3x 16x2 LCD , 1xExternal LED, //-+ potentiometer
// Libarys
#include <Wire.h>
#include <TimerOne.h>
// LCD DISPLAYS
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 16, 2);
LiquidCrystal_I2C lcd2 = LiquidCrystal_I2C(0x26, 16, 2);
LiquidCrystal_I2C lcd3 = LiquidCrystal_I2C(0x25, 16, 2);
// SETUP
//LED + Serialmenu
pinMode(LED_BUILTIN, OUTPUT);
delay(300);
//init display1
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
lcd.blink();
lcd.print("Version: v.0.1");
// init display2
lcd2.init();
lcd2.backlight();
lcd2.setCursor(0,0);
lcd2.blink();
lcd2.print("Lcd2 ready...");
//init display3
lcd3.init();
lcd3.backlight();
lcd.setCursor(0,0);
lcd3.blink();lcd3.blink();
lcd3.print("Welcome...");
delay(4000);
lcd.clear();
lcd.home();
lcd.blink();
lcd2.clear();
lcd2.home();
lcd2.blink();
lcd3.clear();
lcd3.home();
lcd3.blink();
digitalWrite(LED_BUILTIN, HIGH);
delay(30);
digitalWrite(LED_BUILTIN, LOW);
delay(30);
delay(30);
delay(300);
delay(100);
// LOOP
//int sensorValue = analogRead(A0);
if(Serial.available() > 0) {
int incomingData= Serial.read(); // can be -1 if read error
switch(incomingData) {
case '-1':
Serial.println("Error");
case '1':
Serial.print("Get current time");
Serial.write("1");
case '2':
Serial.print("Get PING");
Serial.write("2");
case '3':
Serial.println("Starting Tracert-Test...");
Serial.write("3");
case '4':
lcd.clear();
lcd.setCursor(0, 0);
lcd.blink();
lcd.print("Start PIPE...");
case '!':
Serial.println("!-: Write to LCD");
if (Serial.available()) {
delay(200);
lcd.clear();
while (Serial.available() > 0) {
lcd.write(Serial.read());
case 'v':
Serial.println("Version: v0.1");
lcd.clear();
lcd.home();
lcd.print("Version: v0.1");
// case 'p':
// Serial.println("Potentiometer");
//Serial.println(sensorValue);
// lcd2.clear();
// lcd2.setCursor(0, 0);
// lcd2.blink();
//lcd2.print(sensorValue);
// delay(500);
// break;
case 'c':
Serial.println("Clearing LCD's...");
lcd.print("CLEAR");
lcd.clear();
lcd.home();
lcd.blink();
lcd2.print("CLEAR");
lcd2.clear();
lcd2.home();
lcd2.blink();
lcd3.print("CLEAR");
lcd3.clear();
lcd3.home();
lcd3.blink();
case 'h':
Serial.println("___________________________________________________________________________________________________");
Serial.println("== nemesis_montor | || (c)by BlackLeakz ==");
Serial.println("---------------------------------------------------------------------------------------------------");
Serial.println("== !: Write to display || v: version || i: Led off || o: Led on || x: Led blink || h: Help ==");
Serial.println("== (1): Time || (2): ping || (3): tracert || (4): PIPE || p: Potentiometer1(?) || c: clear ==");
Serial.println("===================================================================================================");
case 'i':
case 'o':
case 'x':
while(true) {
delay(30);
delay(30);
delay(30);
delay(300);
delay(100);
if (Serial.read() == 'm')
return loop();
default:
// handle unwanted input here
