I connect Aeruino UNO and CAP1188 with I2C (scl, sda, reset pin) an everything works great. If I unplug Uno from computer an connect it with external power supply CAPP1188 does not work. I can not figure out why.
Please help!!
Please help!!
Maybe because you forgot to connect the grounds?
I tried both.
In both cases, GND is connected between Uno and CAP.
Post a complete wiring diagram of your setup!
- Uno connected to power supply and CAP to Uno 5V and GND.
According to the datasheet the chip must not be driven with more than 4V.
Are you using the chip directly or is it on a breakout board? If later is true, post schematics of this board!
CAP1188:
Wiring:
sda ----------> sda
sck ----------> scl
rst -----------> D2
VIN ----------> 5V
GND ----------> GND
instructions:
Please specify what "does no work" actually means: Does it simply not detect the touches but the chip is responive and reacts otherwise correctly? Is the chip not visible on the I2C bus? Is the functionality there but not reliable?
