I’m playing around with an Arduino UNO and a CC3000 shield connecting to a remote web service. Though I’m having a problem looping the script. As you can see in the code below, the script should ping the web service with the state of occupied every 5 seconds. Though when using while(client.connected) something makes the Arduino stop/hang forever. Even if the while(client.connected) {} is just empty.
If I don’t include the while(client.connected){} the web service is not pinged, which is why I find myself in quite a dilemma. Please see Arduino Sketch file below and serial log below that.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2); // you can change this clock speed but DI
#define WLAN_SSID "WIFI" // cannot be longer than 32 characters!
#define WLAN_PASS "WIFI_PW"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
uint32_t ip;
int ledPin = 8; // choose the pin for the LED
int ledPinSecond = 7;
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
String occupied;
@brief Sets up the HW and the CC3000 module (called automatically
on startup)
void setup(void)
Serial.println(F("Hello, CC3000!\n"));
displayDriverMode();
Serial.print("Free RAM: ");
Serial.println(getFreeRam(), DEC);
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(ledPinSecond, OUTPUT);
pinMode(inputPin, INPUT); // declare sensor as input
/* Initialise the module */
Serial.println(F("\nInitialising the CC3000 ..."));
if (!cc3000.begin())
Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
while(1);
/* Optional: Update the Mac Address to a known value */
uint8_t macAddress[6] = { 0x08, 0x00, 0x28, 0x01, 0x79, 0xB7 };
if (!cc3000.setMacAddress(macAddress))
Serial.println(F("Failed trying to update the MAC address"));
while(1);
uint16_t firmware = checkFirmwareVersion();
if ((firmware != 0x113) && (firmware != 0x118)) {
Serial.println(F("Wrong firmware version!"));
for(;;);
displayMACAddress();
/* Delete any old connection data on the module */
Serial.println(F("\nDeleting old connection profiles"));
if (!cc3000.deleteProfiles()) {
Serial.println(F("Failed!"));
while(1);
/* Attempt to connect to an access point */
char *ssid = WLAN_SSID; /* Max 32 chars */
Serial.print(F("\nAttempting to connect to "));
Serial.println(ssid);
/* NOTE: Secure connections are not available in 'Tiny' mode! */
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
while(1);
Serial.println(F("Connected!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(1000); // ToDo: Insert a DHCP timeout!
/* Display the IP address DNS, Gateway, etc. */
while (! displayConnectionDetails()) {
#ifndef CC3000_TINY_DRIVER
/* Try looking up the webservice */
Serial.print(F("www.webservice.com -> "));
if (! cc3000.getHostByName("www.webservice.com", &ip)) {
Serial.println(F("Could not resolve!"));
else {
cc3000.printIPdotsRev(ip);
Serial.print(F("\n\rPinging "));
Serial.print("...");
uint8_t replies = cc3000.ping(ip, 5);
Serial.print(replies);
Serial.println(F(" replies"));
if (replies)
Serial.println(F("Ping successful!"));
#endif
/* You need to make sure to clean up after yourself or the CC3000 can freak out */
/* the next time you try to connect ... */
// Serial.println(F("\n\nClosing the connection"));
// cc3000.disconnect();
void loop(void)
val = digitalRead(inputPin); // read input value
occupied = "Occupied";
Serial.print("Room state: ");
Serial.println(occupied);
sendGET();
delay(5000);
void sendGET() //client function to send/receive GET request data.
Serial.print(F("Initializing SendGET request\n"));
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
char serverName[] = "www.webservice.com"; //webservice host
if (client.connect(serverName, 80)) {
//starts client connection, checks for connection
Serial.print(F("Adding state to DB\n"));
client.println("GET /folder/sensor.php?occupied="+ occupied +" HTTP/1.1"); //download text
client.println("Host: webservice.com");
client.println("Connection: close"); //close 1.1 persistent connection
client.println(); //end of get request
Serial.print(F("Ending connection to DB\n"));
Serial.println("Connection to server failed"); //error message if no client connect
Serial.print(F("Checking connection for bytes\n"));
while (client.connected()) {
while (client.available()) {
//Read answer
char c = client.read();
Serial.print(F("Checked for bytes\n"));
Serial.print("disconnecting.");
Serial.print("==================");
client.close(); //stop client
@brief Displays the driver mode (tiny of normal), and the buffer
size if tiny mode is not being used
@note The buffer size and driver mode are defined in cc3000_common.h
void displayDriverMode(void)
#ifdef CC3000_TINY_DRIVER
Serial.println(F("CC3000 is configure in 'Tiny' mode"));
#else
Serial.print(F("RX Buffer : "));
Serial.print(CC3000_RX_BUFFER_SIZE);
Serial.println(F(" bytes"));
Serial.print(F("TX Buffer : "));
Serial.print(CC3000_TX_BUFFER_SIZE);
#endif
@brief Tries to read the CC3000's internal firmware patch ID
uint16_t checkFirmwareVersion(void)
uint8_t major, minor;
uint16_t version;
if(!cc3000.getFirmwareVersion(&major, &minor))
Serial.println(F("Unable to retrieve the firmware version!\r\n"));
version = 0;
Serial.print(F("Firmware V. : "));
Serial.print(major);
Serial.print(F("."));
Serial.println(minor);
version = major;
version <<= 8;
version |= minor;
#endif
return version;
@brief Tries to read the 6-byte MAC address of the CC3000 module
void displayMACAddress(void)
uint8_t macAddress[6];
if(!cc3000.getMacAddress(macAddress))
Serial.println(F("Unable to retrieve MAC Address!\r\n"));
Serial.print(F("MAC Address : "));
cc3000.printHex((byte*)&macAddress, 6);
LOG
Hello, CC3000!
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Free RAM: 1047
Firmware V. : 1.24
MAC Address : MAC_ADDRESS
Attempting to connect to 64 Allen Street - East
Connected!
Request DHCP
IP Addr: XXX.XXX.XX.X
Netmask: 255.255.255.0
Gateway: 192.168.0.1
DHCPsrv: 192.168.0.1
DNSserv: XXX.XX.X.X
www.webservice.com -> XX.XX.XXX.XXX
Pinging XX.XX.XXX.XXX...5 replies
Ping successful!
Room state: Free
Adding state to DB
